Newly Installed Timing Belt
Old Aug 24, 2007 | 06:15 AM
dce's Avatar
dce
Default Newly Installed Timing Belt
I have a 1992 Accord Wagon, 2.2L engine, 189,000 miles, this is the second
time I have changed the timing belt. I had my local mechanic change the
timing belt and he also changed the water pump, crank and cam seals, fan
belts, and valve cover gasket.
After the work was completed, my engine sounds much louder and the tone of
the engine is lower than before. It sounds like someone has tried to soup up
my engine. I took it back to the mechanic and he thinks it sounds fine.
Should the engine sound different after the timing belt and water pump were
changed?
Old Aug 24, 2007 | 07:20 AM
MatterMatt's Avatar
Default Re: Newly Installed Timing Belt (dce)
Not unless the timing is off.
RandyOo
Dec 26, 2013 02:35 PM
BLKFLSH
Dec 20, 2011 11:30 AM
down_the_hatch
Apr 28, 2011 11:41 AM
ezol
Acura TL, RL & ZDX
11
Sep 21, 2010 08:29 AM
dynamyks
Aug 12, 2005 06:38 AM
