Front Splitter Support Rods
Does anyone know where I can pick up a pair of front splitter support rods for fairly cheap?
I've browsed around online and so far I've only found two vendors that carry the support rods (evasive and some other company), but they sell for 40-45$ a set! This seems pretty expensive for two threaded stainless rods...
If anyone could help that'd be great. Perhaps something in the 25-30$ price range would be nice, but if not I'll just pick up the 40-45$ rods.
Thanks in advance!
Thanks in advance!
Thanks a lot ^ ! Still around $45 for a pair, but the CNC aluminum seems a lot better than the stainless. Any others?
[Edit] Thanks for the help, on second thought after shopping around, everything seems to be in the $45-50 price range so I'll just drop the money on what looks best suited to my application.
Thanks again!
Thanks again!
If you built your splitter and mounting brackets properly, there should be no need for support rods...
Check out (Technical ) http://www.specialprojectsms.com
Kiwi
Kiwi
These are $29 a pair:
http://www.cdoc.com/detail.asp...+Arms
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KIWI »</TD></TR><TR><TD CLASS="quote">If you built your splitter and mounting brackets properly, there should be no need for support rods...
Kiwi</TD></TR></TABLE>
Yup, mine probably aren't built well and even mine don't need the supports. If my splitter extended much further out, then mine are probably weak enough that it would need some support.
