How tight to torque
Exeddy Flywheel and a Exeddy Clutch ......... how many ibs to torque the Flywheel bolts and is the specs the same for the Clucth bolts?
for a B18C swaping into a EG
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luvcivics »</TD></TR><TR><TD CLASS="quote">Exeddy Flywheel and a Exeddy Clutch ......... how many ibs to torque the Flywheel bolts and is the specs the same for the Clucth bolts?
for a B18C swaping into a EG</TD></TR></TABLE>
flywheel:76-80lb/ft (i go around 80)
clutch: 18lb/ft (i go around 20-25 because the bolts are most likely stretched a little)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luvcivics »</TD></TR><TR><TD CLASS="quote">so 80ibs is way too much for the clutch bolts but is the rite specs for the Flywheel ?
yeah....the clutch bolts are 10mm. if you put 80lbs on them, they would snap like twigs.
if you tightened them to 80, go buy some new bolts. they're done.
mdj_ge
Dec 7, 2004 12:49 PM
