Engine Mount Control Solenoid...
Old Aug 23, 2007 | 06:38 PM
3litre190's Avatar
Default Engine Mount Control Solenoid...
I'm in the midst of wiring my 95 H22 motor into my 97 Accord. The accord was equipped with the Engine Mount Control Solenoid, which i'm assuming reads the throttle or RPMs to adjust dampening of engine vibrations.
A. Is there a place to wire in the Mount Solenoid on the H22 ECM?
B. If not, is there a place that it can be wired to?
C. If not, what will happen to the solenoid if it isn't opening and closing like it did with the Accord computer controling it?
Old Aug 23, 2007 | 07:05 PM
Eddiebx's Avatar
i;m guessing ur an auot, and keepingit auto?
if so, just pull that solenid, and then cap off the vac, it will make the rear mount stay stiff. whihch is probably needed with the more tq of the h22
Old Aug 24, 2007 | 02:13 AM
3litre190's Avatar
Default Re: (Eddiebx)
well if it runs on the throttle position, would it be possible to piggyback it off something else that reads the throttle position or engine load?
Old Aug 24, 2007 | 04:44 AM
hondaccord's Avatar
Default Re: (3litre190)
you could probably tap into your tps to give it signal voltage, but as stated above, wouldn't stiffen up the mount enough. Just get a solid mount for the rear.
Old Aug 24, 2007 | 04:46 AM
3litre190's Avatar
Default Re: (hondaccord)
its been pretty solid running off the accord ecm (its my DD, so i had to at least make it run on the new motor), but perhaps I haven't tasted the real buck of the engine once its mated to the proper computer. sigh.....
bdr_one
Jan 20, 2015 10:12 AM
webhunter
Jan 7, 2006 03:42 PM
ghostsi69
May 26, 2005 10:03 PM
OutlawCL
Sep 11, 2004 01:20 PM
sysconx
Oct 6, 2003 03:50 AM
