Rust on brand new turbo! need help!
Old Aug 23, 2007 | 05:21 PM
TurboEM1's Avatar
Default Rust on brand new turbo! need help!
Hey guys I am in the process of installing my turbo kit. It is a full race turbo kit with a garrett turbo. Anyway I started it then took like a week off went back to it today and here is my problem.
I have the turbo mounted on the manifold. I never put on the downpipe. I came out today and there is all surface rust on the exhaust turbine part. It is all surface rust on the outside and going into the inside. If you spin the wheel it doesnt hit any of it and the rust went right up to where the wheel is.
If you rub it with your hand it comes right off but is this going to be a problem? The turbo is brand new never used. Can I spray like oil or something in there to clean it out? Please let me know thanks!
Old Aug 23, 2007 | 05:25 PM
RCautoworks's Avatar
Default Re: Rust on brand new turbo! need help! (TurboEM1)
Its fine, you can spray or brush it down but its not going to cause an issue.
Old Aug 23, 2007 | 05:27 PM
bootlegcivic's Avatar
Default Re: Rust on brand new turbo! need help! (RCautoworks)
Just unbolt the exhaust housing from the turbo and take a wire wheel to it. Once all clean spray some high temp clear or black spray paint on it. I used cheap stove paint on mine and is holding up just fine. Or you could be baller and have it coated.
Old Aug 23, 2007 | 05:36 PM
TurboEM1's Avatar
Default Re: Rust on brand new turbo! need help! (bootlegcivic)
Im not talking about the outside. I mean the inside where the turbine wheel is. I would assume you cant paint that but what do I know.
Is it still okay?
Old Aug 23, 2007 | 05:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEM1 &raquo;</TD></TR><TR><TD CLASS="quote">Im not talking about the outside. I mean the inside where the turbine wheel is. I would assume you cant paint that but what do I know.
Is it still okay?</TD></TR></TABLE>
Yep, like I said, you won't have an issue, its surface rust if that
Old Aug 23, 2007 | 06:12 PM
TurboEM1's Avatar
ok thanks!
KevinEF7
May 9, 2014 05:52 AM
gentek1145
Sep 9, 2010 10:36 AM
95whitegizzer
Jun 28, 2006 05:21 PM
eg:R
Jul 28, 2005 05:32 PM
nigel
Apr 5, 2004 12:46 PM
