Brake/Rotor Help
Old Aug 23, 2007 | 03:30 PM
RickyBizee's Avatar
Default Brake/Rotor Help
Im going to attempt to try to replace my brake pads and rotors on my 97 Civic HX, Im not very adept mechanically, but Im struggling right now and can't afford to take it to a shop. I have most of the tools I think i will need, I do car audio for a living so I do have tools....But I have been asking around at work and other friends, and they are Saying I will possibly need a caliper pressure tool? So Im starting to think this process won't be as easy as I think....
If anyone could please give me a quick run by on what exactly I'll need as far as tools, and procedures Ill need to take...I was hopeing this would be somthing easy like unbolt then bolt back on but im sure its not. So any helpful tips or maybe tutorials known out on the web would be greatly appreciated!
Thanks for the help in advance.
Old Aug 23, 2007 | 03:37 PM
EL Vap133's Avatar
Default Re: Brake/Rotor Help (RickyBizee)
https://honda-tech.com/zerothread?id=1938057
It will be easy, even on your first try. You don't really need a caliper compression tool, I sometimes use a pipe or something that can push the caliper in using manual force.
Old Aug 23, 2007 | 03:46 PM
RickyBizee's Avatar
Thanks so much man! Im not so scared now lol
Old Aug 23, 2007 | 03:52 PM
EL Vap133's Avatar
Default Re: (RickyBizee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RickyBizee &raquo;</TD></TR><TR><TD CLASS="quote">Thanks so much man! Im not so scared now lol </TD></TR></TABLE>
No need to be scraed, just don't break any of the lines open or you'll have to bleed the brakes.
Old Aug 23, 2007 | 05:29 PM
BlueIntegraBoy's Avatar
Basically a set of sockets and wrenches. I use the hammer's handle end to compress the caliper piston back.
Old Aug 23, 2007 | 11:20 PM
RickyBizee's Avatar
Cool, I was starting to get a lil shaky for a second...thnx for the reassurance guys!
Old Aug 24, 2007 | 07:30 AM
EL Vap133's Avatar
Default Re: Brake/Rotor Help (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Basically a set of sockets and wrenches. I use the hammer's handle end to compress the caliper piston back.</TD></TR></TABLE>
LOL, I do the same! Sometimes I use the big ratchet!
Old Aug 24, 2007 | 09:40 AM
instructor74's Avatar
Default Re: Brake/Rotor Help (EL Vap133)
The only thing you might have a problem with is if you have rear discs you CAN'T just push the piston back in it MUST be turned and pushed back in this is made a bunch easyer with the right tool.
JDM Dylan
10
Mar 9, 2008 05:31 PM
92civicx
15
May 9, 2007 01:16 PM
Meatwad1355
Apr 4, 2007 10:39 AM
justanek9
Oct 2, 2005 08:07 PM
BlownVR
13
May 17, 2004 01:05 PM
