'90 Civic 16 Valve idling up and down
Old Aug 23, 2007 | 03:18 PM
drumforever's Avatar
Default '91 Civic 16 Valve idling up and down
Once the engine gets warmed up, the idle drops until the car almost dies and then revs back up. Then it starts the whole process over. I looked around the internet elsewhere before i posted here, but its usually newer cars than mine that they're talking about. Also, people give part names that don't exist in my manual like IACV??
My CEL is not on and I do not have a tachometer to check the idle.
Any suggestion?
Modified by drumforever at 4:46 PM 8/23/2007
Old Aug 23, 2007 | 04:09 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: '91 Civic 16 Valve idling up and down (drumforever)
What manual do you have? It's either called the IACV or EACV (Idle or Electric Air Control Valve).
Try taking it off and cleaning it first.
Here's how:
https://honda-tech.com/zerothread?id=1575913
That process is for an Integra, but it's exactly the same for your vehicle. Good luck!
Old Aug 23, 2007 | 04:28 PM
maxx5905's Avatar
Default Re: '91 Civic 16 Valve idling up and down (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">
Here's how:
That process is for an Integra, but it's exactly the same for your vehicle. Good luck!</TD></TR></TABLE>
Old Aug 23, 2007 | 05:59 PM
It's called an EACV in my manual. Mine is a copy on disc. It just says Shop Manual on the image of the front cover. It also says it's for an 88 if that makes any difference.
Old Aug 23, 2007 | 07:13 PM
garageEF's Avatar
try flushing and filling your cooling system. and make sure you bleed it correctly like the manual says.
Old Aug 23, 2007 | 08:10 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: '91 Civic 16 Valve idling up and down (garageEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garageEF &raquo;</TD></TR><TR><TD CLASS="quote">try flushing and filling your cooling system. and make sure you bleed it correctly like the manual says.</TD></TR></TABLE>
Ahhhh, I always overlook this one for some reason. It may be due to an air bubble in the coolant as well.
Old Aug 25, 2007 | 09:43 AM
So far I guess it was an air bubble. It seems to be running fine now. This is my first Honda and I have never EVER heard of bleeding the coolant system, at least not in any American car I've ever owned. Thanks for the help guys!
mattdenali
May 19, 2005 06:26 AM
Armed Ferret
Dec 22, 2004 11:19 PM
RACEPAK
Nov 28, 2004 12:58 PM
RacerMike
Jan 29, 2003 08:49 AM
