Pulled the spark plugs and they're covered with fuel...
Old Jun 13, 2002 | 05:02 PM
travis's Avatar
Default Pulled the spark plugs and they're covered with fuel...
I was changing out the spark plugs in the rex today, and when I pulled the first one I found that it was covered in fuel. Not just a little, but dripping wet. I pulled the rest and they were all the same. The car hasn't been run in over a month, and when it was run it was only run for a total of 15 seconds at a time, just enough to pull it in/out of the garage to work on it.
I'm going to pull the valve cover tomorrow and at least do a valve adjustment (unrelated) and a fresh falve cover (maybe related, although the plug wires are dry) and I'll let you know if I find anything fishy. In the meantime, should I be worried about this? I'm thinking it's a result of sitting for long periods with super short periods of running cold and then being turned off again right away. But, I'm not sure. Ideas?
Old Jun 14, 2002 | 01:18 AM
matt_sb2000's Avatar
Default Re: Pulled the spark plugs and they're covered with fuel... (ITR#231)
reeky injectors? What year is it 88-91? Valve adjustments aren't going to help that but it is good to do them..... If it is 88-91 and dx I would deffinatly suspect the injectors.
Old Jun 14, 2002 | 05:41 AM
travis's Avatar
Default Re: Pulled the spark plugs and they're covered with fuel... (matt_sb2000)
Sorry, the info is in my sig. It's an 88 Si.
Old Jun 15, 2002 | 02:12 PM
travis's Avatar
Any other suggestions? I'll obviously re-check the plugs after the car has been running for a much longer period of time, but for now (while I have it apart) I just wanted some ideas. Thanks!
joe.wong321
20
Mar 5, 2008 07:21 PM
Mik3
Jan 27, 2006 12:35 PM
Hazem
Jan 8, 2005 01:49 PM
mattmw88
Feb 22, 2002 07:54 AM
