Hondata Intake Mani Gasket
Old Aug 23, 2007 | 01:38 PM
EGLUVN's Avatar
Default Hondata Intake Mani Gasket
Is it really all its cracked up to be. Ive heard good things and I wanna know your guys' opinions.
Old Aug 23, 2007 | 03:11 PM
instrument's Avatar
it's like "the power of Christ compels you"
and ****.
Old Aug 23, 2007 | 05:35 PM
ricekiller1's Avatar
Default Re: (instrument)
i would also like to see a "none smart ***" answer to this question
Old Aug 23, 2007 | 05:49 PM
Padawan's Avatar
Darth ModerVader
Default Re: Hondata Intake Mani Gasket (EGLUVN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGLUVN &raquo;</TD></TR><TR><TD CLASS="quote">Is it really all its cracked up to be. Ive heard good things and I wanna know your guys' opinions.</TD></TR></TABLE>
I don't really know that it's been "cracked up" to be all that much, other than a simple phenolic spacer. It does help insulate the intake manifold, especially when one disconnects the coolant flow along with it. However, I would not expect monumental gains, nor would I go through the effort of installing one unless I was already going to have the IM off for another reason.
Old Aug 24, 2007 | 12:15 AM
EGLUVN's Avatar
Default Re: Hondata Intake Mani Gasket (Padawan)
thinking about buying one when i get rid of my stock gsr mani and get the skunk2 mani
Old Aug 24, 2007 | 01:58 AM
1BADEGDC2's Avatar
its a little thicker than a stock one, might have trouble getting it on, thats why i sold mine and just bought an oem one
Old Aug 24, 2007 | 05:44 AM
StreetRacin101's Avatar
I am actually getting ready to get rid of mine. I have a genuine Hondata version (there are a million knock-offs now) and with the underhood/engine temps its begun to warp and actually created a vacuum leak. Not at all as durable as I thought it was suppose to be.
Old Aug 27, 2007 | 04:48 PM
Default Re: (StreetRacin101)
so bottom line seems to be that its more trouble than its worth???? would everyone agree???
Old Aug 27, 2007 | 05:15 PM
Crx Jimmy's Avatar
Default Re: (ricekiller1)
depends on if you plan on taking the manifold off a lot, if not go oem, if you do then it saves a LOT of time having to scrape the old gasket off
Old Aug 27, 2007 | 05:48 PM
pdiggitydogg's Avatar
You need to use extended studs with it - personally, I wouldnt want to do that with the engine/head in the bay... I replaced one stud once and that was pita enough for me.
There is a specific torque procedure for it, too.
Personally, I dont think the hondata version is worth the money, however, the ebay brand at less than 1/2 the price may be...
Old Aug 27, 2007 | 05:56 PM
vtecftw's Avatar
if you dont have the reg gasket completely scraped off it will not seal correctly. might as well have the motor out to do it correctly
Old Sep 17, 2007 | 04:15 AM
TheSauceSpot's Avatar
Default Re: (vtecftw)
if you have the motor out and are changing the intake manifold anyway... is it worth it to use this gasket?
is there any real advantage over using oem?
disadvantages?
new studs? where can you get them? anything else you need?
recognize408
11
Jun 25, 2006 11:03 AM
B-B-K
23
May 4, 2005 08:43 PM
LAQUALO101
Sep 7, 2004 02:49 PM
EKB18BPR3
Jun 27, 2004 08:09 PM
ITSTOCK
Jan 12, 2004 02:46 PM
