Suspension
ok guys i need some help here.
i have an EJ8 and, of course it only has front disk brakes, but pretty soon will be swapping to rear disk brakes as well.
but i do need new suspension since im rolling on stock shocks and drop zone coilovers. the thing is, i was about to order the tokico illumina shocks and ground control coilovers, the question here is if i could use the same suspension setup on the rear disk brakes??
tia
tia
Your braking assembly has nothing to do with the suspension. The two systems are independant of eachother. BTW, if you do swap the entire trailing arm in, they are also the same, so nothing changes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MDM »</TD></TR><TR><TD CLASS="quote">orale... so say i get the swap from an si or even something else that fits, the shocks still bolt up to the lca (plug and play)??</TD></TR></TABLE>
If you use Integra rear disc brakes, swap out the LCAs so that you use your stock ones. If you use 99-00 Si rear disc brakes, you can use those LCAs on your 96-00 Civic. Let me know if you have any other questions loco!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MDM »</TD></TR><TR><TD CLASS="quote">simon ese.. ill pm u if i do, but for now, thanks to all
No problem
</TD></TR></TABLE>No problem
could any one help me i have a 00 civic si it has skunk 2 coil overs i like how the car looks cause its low but it rides like **** does anyone know a good suspension set up that rides good but is still low? Should i get springs or what?
Modified by ahoffmann at 8:55 PM 8/29/2007
