Buying JUN stage 3 cams..for my R..What should I do???
Old Jun 13, 2002 | 04:44 PM
typevimports's Avatar
Default Buying JUN stage 3 cams..for my R..What should I do???
I am buying jun stage 3 cams for 98 itr and I am thinking about what valve springs and retainers to buy with them. Also I am thinking about a hondata ecu stage 3 and I am tuning it on a dyno for the best results. What would or did you guys do?????
Old Jun 13, 2002 | 04:47 PM
SuperTwinz's Avatar
Default Re: Buying JUN stage 3 cams..for my R..What should I do??? (typevimports)
try using the search engine...
Old Jun 13, 2002 | 04:53 PM
Rob :190:'s Avatar
Default Re: Buying JUN stage 3 cams..for my R..What should I do??? (chomp_on_this)
dont type rs get mid 14s stock?
Old Jun 13, 2002 | 05:34 PM
Alaskan98ITR406's Avatar
New User
Default Re: Buying JUN stage 3 cams..for my R..What should I do??? ( Rob)
Got a set in stock, drop me a line if you need a JUN III Head Package.
Old Jun 13, 2002 | 05:36 PM
R-1303's Avatar
GET the whole head package!! but i would waste my good earn money on boost
Old Jun 13, 2002 | 05:56 PM
AllMotorITR's Avatar
New User
Default Re: Buying JUN stage 3 cams..for my R..What should I do??? (R-1303)
I would get the Jun Valvetrain, Portflow Ti Retainers, Hondata stage 2, CTR Pistons, Hytech Header, and Hytech Exhaust.... Or you could just get some Toda Bs and call it a day.
Old Jun 13, 2002 | 05:59 PM
GokuSSJ4's Avatar
Default Re: Buying JUN stage 3 cams..for my R..What should I do??? (1 FAST R)
or jun everything
Old Jun 13, 2002 | 07:01 PM
Mr. Softee's Avatar
Default Re: Buying JUN stage 3 cams..for my R..What should I do??? (Spoon1)
put em in car.
Old Jun 13, 2002 | 08:19 PM
Black R's Avatar
25 Year Member
2L bottom end would go real nice with those cams.....
You might also wanna get JUN everything else to go with them.....
Old Jun 13, 2002 | 08:37 PM
1 2 NV's Avatar
u might also want to remember that if anything goes wrong with those JUN cams u better make sure u were runnin all JUN springs, retainers or else they wont do **** for ya. JUN rules.
Old Jun 13, 2002 | 08:49 PM
sneakychaos's Avatar
Default Re: Buying JUN stage 3 cams..for my R..What should I do??? (hondaatwsu)
What a vague question. What are you trying to do with your setup? Run mid 14's? I ran 14.3's all day with my old R with just an AEM intake, what are you doing wrong?
Also, how much are you planning on putting into your car? Are you going to raise compression? Are you going to build the bottom end? Whats type of goals have you set for yourself with picking up cams?
I'm not trying to be a smartass, but these are all questions you need to answer before you take everybody elses opinion about what to buy. Give us some more information on your goals, and we can all help you out tremendously.
Also, recommended to use the search function and get a little background on what others have used/asked, and what they've hit with their cams.
austrian type-R
Jul 2, 2004 05:20 AM
ajchen
Dec 19, 2002 11:25 PM
Xb16aX
Jan 18, 2002 12:34 AM
enthusiast128
Oct 14, 2001 11:09 AM
