95 accord wheal bearings
im planning on changing the front rotors on my accord and i hear that its a pain. if not done properly I hear that you might have to replace the wheel bearings which I kind of want to do anyways while I have everything apart. changing the bearings may also be a solution to one of my other problems that i posted on here (95 accord screeching noise from wheel). The partsource store in my town offers aftermarket wheel bearings for $85 or I can get an economy hub with wheel bearing in it for only $65 (which is also a plus since I wont have to go to a garage to have the bearing pressed into my old hub). I'm kind of leary about buying aftermarket bearings, especially the economy hub/bearing combo, I dont want to have to replace it again in 6 months. Anyone have any bad experiences with aftermarket bearings, should I shell out more and get OEM?
I got mine from Kragen. Then do the 25% off coupon. I think mine went for like 50-60 ish. I forgot. But I had no problems. Changing front rotors on 5th gen is the worst. I had some rust on mine, and it is just takes lots of patience. Well good luck!
charliecd5
Feb 12, 2015 06:01 PM
B18C_EJ8
Apr 9, 2007 03:42 PM
