catalytic converter please help!! obd2 2000 si
Old Aug 23, 2007 | 10:32 AM
ek82's Avatar
Default catalytic converter please help!! obd2 2000 si
just wondering if this is possible- obd2 accord cat cut and weld into a 2000 si??? i dont want to spend a whole lot on a cat cuz i am getting test pipe later
Old Aug 23, 2007 | 12:27 PM
t0p_sh0tta's Avatar
Default Re: catalytic converter please help!! obd2 2000 si (ek82)
Sure.
Old Aug 23, 2007 | 01:00 PM
97Ej6mike's Avatar
Can be done, what problem are you experiencing that you would go to such trouble tho?
Take Note: according to your profile you are from Cali, i am not sure if you are aware of the smog and emmisions regulations in your state. Any sort of test pipe would probably be a bad idea.
Old Aug 23, 2007 | 01:33 PM
ek82's Avatar
Default Re: (97Ej6mike)
man i just wanna past smog for a change of ownership...... also a obd2 cat for an si is expensive only to use one or two times. the obd2 cat from the accord is free but just wondering if everything plug in and play or i would have to cut and weld.
Old Aug 23, 2007 | 01:46 PM
t0p_sh0tta's Avatar
Default Re: (ek82)
A cat is a cat for the mostpart. It doesn't have to be OBD2. Have the one from the Accord welded on and hope for the best.
Did the car fail inspection? If so, by what and how much?
Old Aug 23, 2007 | 01:48 PM
ek82's Avatar
Default Re: (t0p_sh0tta)
i thought the difference between obd1 and obd2 cat is the o2??
Old Aug 23, 2007 | 01:51 PM
t0p_sh0tta's Avatar
Default Re: (ek82)
If you're having a shop install the cat, they can also install an O2 bung if you need it.
Old Aug 23, 2007 | 11:29 PM
ek82's Avatar
just wondering how long is the si cat?
Old Aug 23, 2007 | 11:33 PM
ek82's Avatar
Default Re: (ek82)
o yea and do i have to get an extension for a o2 if the plug in for the o2 is in the front instead of the middle??
Old Aug 24, 2007 | 10:06 AM
ek82's Avatar
Default Re: (ek82)
anyone??
Old Aug 24, 2007 | 10:22 AM
97Ej6mike's Avatar
Default Re: (ek82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek82 &raquo;</TD></TR><TR><TD CLASS="quote">o yea and do i have to get an extension for a o2 if the plug in for the o2 is in the front instead of the middle??</TD></TR></TABLE>
I dont think that will help your situation, you need to have the secondary 02 sensor behind the CAT
Old Aug 24, 2007 | 01:06 PM
bballchris24's Avatar
Default Re: (ek82)
a cat for an si is 16 3/4"
Tegra206
Sep 2, 2015 04:39 PM
theslugbug
Sep 30, 2009 11:49 AM
95ex5speed
Oct 20, 2004 08:52 AM
m0t0rhead
May 7, 2002 05:16 AM
