Antisway Bar on EX
do a search..
but luckly for you i am selling an itr rear swaybar. it is 22mm. i am selling the bar, the brackets, the bushings and the si endlinks, and the beaks reinforcment kit.
this is all you need. the only thing you will have to mod is you have to drill one hole in each lower control arm.
it has never been used. i am selling it for 200.00 plus shipping
thanks
thanks
I did do a search and found only the si to fit into the stock holes but that was said to cost $250 for the kit. Was wonder if any aftermarket sway bars were like the SI but cheaper. Skunk2?
I have a 97 EX w/ ST front and rear sway bars. They are great. In the rear you have to drill one hole into the crossmember. look on overboost.com there is an article about it.
Hemix
Dec 6, 2006 04:17 PM
