idle problems
Old Aug 23, 2007 | 10:22 AM
durfeec's Avatar
Default idle problems
i have a b18a1 in my crx and sometimes the idle will jump up and down when i come to a stop and then it will stop on its own.
there is no check engine lights on and idk what the problem is. maybe a sensor is bad but not showin up on the CEL?
can someone help me?
Old Aug 23, 2007 | 10:43 AM
alscrx's Avatar
Default Re: idle problems (durfeec)
Any codes on ecu??? If not could be EACV or fast idle valve
Old Aug 23, 2007 | 10:53 AM
durfeec's Avatar
Default Re: idle problems (alscrx)
idk anything bout the ecu stuff. how do i check for codes on the ecu?
Old Aug 23, 2007 | 11:11 AM
90_Si's Avatar
This helped stabalize mine alot.
https://honda-tech.com/zerothread?id=1575913
Old Aug 23, 2007 | 12:26 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (90_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90_Si &raquo;</TD></TR><TR><TD CLASS="quote">This helped stabalize mine alot.
https://honda-tech.com/zerothread?id=1575913</TD></TR></TABLE>
Try this first, if it doesn't fix it, try cleaning the FITV.
Old Aug 23, 2007 | 12:35 PM
denraweb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by durfeec &raquo;</TD></TR><TR><TD CLASS="quote">idk anything bout the ecu stuff. how do i check for codes on the ecu?</TD></TR></TABLE>
Pull the carpet back from the passenger side floor board. There will be a big gold bracket that protects the ECU. On that bracket, there will be a clear lens, like a peep hole. From there, a light will be flashing if there is a problem with something electrically. If there is a light flashing, read the flashes. For each LONGER blink will be multiples of 10. The shorter blinks indicate 1's. After a long pause, it will either throw a different code, or redo the same code. Write down the number of the code and look it up.
For example: two long blinks and then one short blink will indicate a code 21, vtec solenoid/spool valve.
Old Aug 23, 2007 | 01:18 PM
90_Si's Avatar
I think on non obd it is only short blinks, if it is obd1+ it will have the 10s and ones blinks.
Old Aug 24, 2007 | 02:40 PM
durfeec's Avatar
Default Re: (90_Si)
would any of these things give me bad gas mileage?
Old Aug 24, 2007 | 02:48 PM
DenzComp's Avatar
Default Re: (durfeec)
Check your coolant level.
Old Aug 24, 2007 | 07:56 PM
durfeec's Avatar
Default Re: (DenzComp)
why would that give me bad gas mileage? wouldnt that just make my engine overheat?
Old Aug 25, 2007 | 05:35 AM
DenzComp's Avatar
Did I say it would give you bad gas mileage?
The title of this thread is "idle problems"
When I went from DPFI to MPFI I was so excited that it started I forgot to put the coolant back in. I took it for a spin around the block and every time I stopped the idle was surging.
I checked a bunch of other crap before I realized I had forgot to put the coolant back in.
Old Aug 25, 2007 | 09:50 AM
Aristotle's Avatar
Make sure that you don't have any vacuum leaks or loose vacuum hoses, especially by the intake manifold. Check the TPS with an ohmmeter. You might be able to find Specs somewhere in here.
Spikey640
Aug 14, 2008 09:40 PM
djkid17
Apr 17, 2007 07:27 PM
turborex
10
Mar 16, 2006 03:39 PM
Mr_CRX
20
Sep 15, 2004 11:26 AM
quik2kSi
Dec 27, 2003 09:04 AM
