Fueling issues
Hey guys I am having a surging idle issue with my car and can't seem to find the problem. I had the original f22a1 intake on it and it surged after I did my boost setup. I changed to a h23 intake on this install and it is still surging. I can't seem to get it to stop the wawawawa 1200rpm thing, this also causes it to be jerky in normal low speed/low rpm driving. I know when I turn my key over the fuel pump never turns off, if I were to just turn the key to the on position and not start the pump would run until the battery died...
It didn't do this when I first put the Walbro 255lph pump in, could this be the cause of my surging idle problem? Why does my fuel pump not stop priming?
I haven't found any leaks. I am getting a code 14 for the IACV but have tried 2 known working ones. I think that I will check the connection on the ECU today when I get home from work. Does this make the idle and near closed throttle hesitant and bouncy?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thomas188 »</TD></TR><TR><TD CLASS="quote">FSM? I am sorry</TD></TR></TABLE>
Factory Service Manual
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thomas188 »</TD></TR><TR><TD CLASS="quote">I haven't found any leaks. I am getting a code 14 for the IACV but have tried 2 known working ones. I think that I will check the connection on the ECU today when I get home from work. Does this make the idle and near closed throttle hesitant and bouncy?</TD></TR></TABLE>
Hmmm, I wonder what the problem could be...
Yes the IACV is what controls the idle so you might wanna start there.
MKEK9
11
Mar 6, 2007 04:55 PM
Mister Jew
Apr 12, 2006 05:53 PM
