Which pinouts are for the TPS Sensor on a p13 ECU h22 civic!
Which Pinouts are for the TPS Sensor in the P13 ECU! My brother and I a extremely frusterated in trying to figure this out! This is the last code that I need to get rid of, and waalah! No check engine lights.
Any help would be appreciated!
Thanks
Modified by Preludes'R'Us at 5:35 PM 8/23/2007
Thanks
I tried to search for it but the site kept saying the search is down! I was also wondering if you can use the 92-95 civic tps sensor for the h22 motor, because they look exactly the same.
DOES THE CIVIC 1.5L TPS SENSOR WORK FOR THE H22A MOTOR! I KNOW YOU GUYS CAN ANSWER THIS!
Check your pm's! Any tps sensor that is from a multi port fuel injected honda will work. A duel PMF will work too but u have to switch the outer wires. Remember to correctly calibrate the tps sensor to .45-.5V at idle.
