JDM no Vtec Pressure Switch?
well some jdm motors dont have it
so im throwing a code for the switch *cel 22* and my oil pressure is good and i have a
jdm h22
if its not present on some motors then can i take mine off?
seems like its not needed?
Modified by xXSilentScreamXx at 12:11 PM 8/24/2007
jdm h22
This happend with an H22 swap I helped do, to be honest I dont remember exactly how we did it, but I know its possible to somehow fix the cel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xXSilentScreamXx »</TD></TR><TR><TD CLASS="quote">but see i have the switch
is it still ok to bypass it?</TD></TR></TABLE>
You can. It's only there for a preventative measure to only engage VTEC if there's enough oil pressure.
If you have the switch, why not hook it up ? Am I understanding this correctly, you have it, but your throwing a code cause its not hooked up, and you want to get rid of it ?
Just hook it up.
Just hook it up.
CEL light..car just immediately backs off (as if you slammed on the brakes, the whole car jolts)..and if you try to accelerate passed 5500 the car will do the same thing.
happened to me a week and half ago. just reset ECU by unplugging the battery and your on your way.
EDIT: not sure what CEL it is either cause it doesnt blink it just stays on...i reset the ECU, put 4 qts of oil and it didnt happen again.
Hi.
First off code 4 is not related to the VTPS. Code 22 is.
Code 4 = CKP sensor (crank position sensor)
check it out here:
http://www.ff-squad.com/tech/ecu/mil-codes.jpg
The CKP sensor is in the dizzy. I suggest trying a different distributor.
check it out here:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Probot »</TD></TR><TR><TD CLASS="quote">EDIT: not sure what CEL it is either cause it doesnt blink it just stays on...i reset the ECU, put 4 qts of oil and it didnt happen again.</TD></TR></TABLE>
Dude Check your Oil More offten and you might not need to put in 4 Qts of oil to get in back to full.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xXSilentScreamXx »</TD></TR><TR><TD CLASS="quote">bump
waht happens if vtec engages and theres not enouff oil pressure? </TD></TR></TABLE>
Um, its a sign, your engine won't rev that high or engage vtec cause you have an issue. Don't half *** the job, hook the sensor up the correct way and make use of the sensor itself.
