Car Won't Start
I have a 2003 honda civic with a d17a2 i put my turbo kit on my car, am useing the greddy emanage ( blue) i went to start it for the first time and the car won't start, i disconected the emanage and plugged it back into the factory ecu with out the pig tail.
I checked the car is getting gas, but not spark, i'm not sure if the injectors are spraying or not.
Does anyone know what it might be, have you had this problem before, does the emange have to be set up before the car is even started for the first time.
Thanks for your help, Please don;t leave post saying anything negative, i just really need everyones help.
Thanks,
Matt
Thanks,
Matt
so since i had the plug and play harness unpluged i checked all the fuses and the ing. coil fuse was blown i changed it out then started the car, the car started but was very rough, i then turned it off within 20 sec.
I went to install the plug and play harness and started the car but itwont start again , checked the fuse and it blew it again, does anyone know why this might be, i have to take the car to knoxville today at 5pm to get it tuned by blindside imports, and that's around a 2 hour trip.
em1gangsta
Jun 29, 2008 01:29 PM
90crxdriver
Apr 17, 2008 05:12 AM
