sharp "click", almost like a chirp noise fixed!
Old Jun 13, 2002 | 03:21 PM
01PYTypeR#1140's Avatar
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
Default sharp "click", almost like a chirp noise fixed!
__________________________________________________ __________________
When I pull off from a stop or accelerate, I get a click noise coming from the wheels. It is just a sharp "click", almost like a chirp. It is not continuous. a few clicks and it stops.
Well, after 3 days Acura gives me back the R, and guess what it's fixed! I asked them what the problem was and thay said they didn't know They pulled my axles to replace them, but mine were in perfect condition so they reinstalled them, and checked the vehicle again the noise was still there. So they lifted her back up and torqued everything up front to spec. and he said I mean everything, and when they took her out again problem solved. He told me to keep him posted, but he thinks I won't have this problem again. Sorry, but they said they have no idea what caused the noise, but after they torgued everything I can't get it to make the noise under any situation. Take it to Acura and have them torque everything and your problem will be solved. I think I caused the problem doing some fun runs at a auto-x where I did some extreme drifting, and the R hooked so hard that my helmet hit the drivers window a few times, because after that my door didn't open or close the same for a few days, then it went back to normal.
[Modified by 01PYTypeR#1140, 7:24 PM 6/13/2002]
[Modified by 01PYTypeR#1140, 7:30 PM 6/13/2002]
Old Jun 13, 2002 | 03:22 PM
Reid's Avatar
Global Moderator
Default Re: sharp "click", almost like a chirp noise fixed! (01PYTypeR#1140)
Glad to hear it's fixed.
Now if i could only figure out what the problem was.
Old Jun 13, 2002 | 03:27 PM
Cheap Bastard's Avatar
New User
I have the same problem in my Si. When a accelerate it clicks once, then when I let off the throttle it clicks again. I have no idea what's wrong with it. I think it started to happen after my car got towed.
CB
Old Jun 13, 2002 | 04:02 PM
Rob :190:'s Avatar
you had your window up at an autocross? is that allowed?
Old Jun 13, 2002 | 04:06 PM
Default Re: sharp "click", almost like a chirp noise fixed! ( Rob)
No, but it was during some fun runs.
Old Jun 13, 2002 | 04:09 PM
Rob :190:'s Avatar
either way, lucky you didnt shatter your window with your helmet...
Old Jun 13, 2002 | 05:59 PM
Cosworth's Avatar
No kidding... surprised that the organizers didn't catch you.
Old Jun 13, 2002 | 06:24 PM
The Toecutter's Avatar
Thanks for the follow up post. Time to torque the front suspsension down..........
Old Jun 13, 2002 | 07:45 PM
EagleR's Avatar
Default Re: sharp "click", almost like a chirp noise fixed! (Velocity)
thats what I'm thinkin...nah screw it Acura has 7 other warranty things to fix so I'll let them do it...
Old Jun 13, 2002 | 10:09 PM
Faust's Avatar
In Germany we have to have the windows up. Wierd.
Old Jun 14, 2002 | 04:50 AM
Track rat's Avatar
Default Re: sharp "click", almost like a chirp noise fixed! (Faust)
Next time you hear the click, turn the a/c off and try again. If you can't get the sound to occur with the a/c off, it's probably the a/c clutch. I had the same problem, when I accelerate hard the clutch momentarily disengages, and the click/chirp is the clutch hooking back up. The center retaining bolt on the a/c clutch had loosened up, I tightened it and the chirp is gone.
Old Jun 14, 2002 | 05:01 PM
Default Re: sharp "click", almost like a chirp noise fixed! (Track rat)
Not A/C related, because I hardly ever use it.
[Modified by 01PYTypeR#1140, 9:02 PM 6/14/2002]
Old Jun 26, 2002 | 01:16 PM
lanceh's Avatar
25 Year Member
i'm having this exact same problem. car is at the dealer right now and they are telling my it's from the non OEM pads i installed.
the pads are R4S and there is a little bit of play up and down when seated in the caliper.
i originally thought it was coming from the clips in the caliper but i removed the clips and it made the exact same noise. even if it was from the extra play it woudn't make the exact same noise when they were removed because the pads would banging against a different type of metal. caliper metal vs. clip metal
it's only coming from the left wheel and i had someone look at the wheel when the noise occured and you can see the entire hub shaking for a second.
[Modified by lanceh, 5:18 PM 6/26/2002]
Old Jun 27, 2002 | 06:56 PM
Rwecked's Avatar
Default Re: sharp "click", almost like a chirp noise fixed! (lanceh)
Got the same thing goin on. Just torque it all down huh? What was the labour on that? Any other possible answers/solutions before I go nuts replacing parts?
Old Jun 27, 2002 | 07:21 PM
GRM Scott's Avatar
25 Year Member
i have a similar sound, but i can't see how it would be pads...it happens when you go from throttle to off-throttle, but not with the brakes...so as far as the pads are concerned, the disc is still going the same way. I wonder if anyone can nail this down definitively...
Old Jun 27, 2002 | 07:42 PM
davidnyc's Avatar
My dealer said the same thing !!! They said the R-4S pads were making the clicking sound.
Maybe in a weekend or two, I'll wip out the Helm's and just torque every single front suspension bolt.
Old Jun 27, 2002 | 09:33 PM
lanceh's Avatar
25 Year Member
Default Re: sharp "click", almost like a chirp noise fixed! (davidnyc)
it's the typical bullshit answer as soon the dealer sees that you've worked on the car yourself. i would be suprised if they even took the wheel off. as soon as the saw the pads and found out that i changed them that was the cause.
pads are the cause was the final word from the dealer i took the car to. so i put the stock pads back in and will take it to another local dealer next week. fugging dealers suck ***.
[Modified by lanceh, 1:36 AM 6/28/2002]
Old Jun 27, 2002 | 09:38 PM
After Acura torqued everything I can't get it to make the noise under any situation. Take it to Acura and have them torque everything and your problem will be solved, unless you're no longer under warranty.
Golfnut
Jun 26, 2013 08:38 AM
wxy117
Mar 24, 2008 10:26 PM
typeee
Nov 21, 2003 01:05 PM
