changing gear oil and in trouble!
Old Aug 22, 2007 | 05:18 PM
hatcht9x's Avatar
Default changing gear oil and in trouble!
.. i have a 91 hatch with a b16 swap... i bought it a month or so ago, and most times (when it is cold) when I put it into reverse, it grinds. i thought that might be due to not having enough gear oil, but when i unscrewed the fill plug a **** load of gear oil started to come out!! I put the plug back in and came here for help!! the car is on the rack and i need help quick!! please help!!
p.s. if it wasnt the lack of gear oil, why is my reverse grinding?
PLEASE HELP!!!!! THANK YOU!!
Old Aug 22, 2007 | 05:25 PM
garageEF's Avatar
Default Re: changing gear oil and in trouble! (hatcht9x)
jack up the right side of the car. and you must wait for it to be completely cool.
Old Aug 22, 2007 | 05:27 PM
hatcht9x's Avatar
Default Re: changing gear oil and in trouble! (garageEF)
why jack the right side?
Old Aug 22, 2007 | 05:36 PM
MRN1120's Avatar
https://honda-tech.com/zerothread?id=1520463 Read the 4th post down
Old Aug 22, 2007 | 05:39 PM
Pee Wee's Avatar
Default Re: changing gear oil and in trouble! (MRN1120)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MRN1120 &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1520463 Read the 4th post down</TD></TR></TABLE>
This is correct. Its such a bad habit now that i do it in all cars that i drive
Old Aug 22, 2007 | 05:42 PM
hatcht9x's Avatar
THANK YOU SOOOO MUCH MAN...... I WAS SCARED FOR MY TRANNY AND THAT DOES MAKE ALOT OF SENSE!! thanks again!!
Old Aug 22, 2007 | 05:44 PM
VtecSyndrome's Avatar
Default Re: changing gear oil and in trouble! (Pee Wee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pee Wee &raquo;</TD></TR><TR><TD CLASS="quote">
This is correct. Its such a bad habit now that i do it in all cars that i drive </TD></TR></TABLE>
Thats funny, I started doing that in my first car back in '96 in my '88crx Si and have been doing it ever since as well..I can't even remember where I heard it from. never really thought about why
Old Aug 22, 2007 | 07:28 PM
Jonknee's Avatar
Default Re: changing gear oil and in trouble! (VtecSyndrome)
When ppl drive my car and i tell them to shift from 1 and then reverse they think im retarted lol
Old Aug 22, 2007 | 07:37 PM
93projectda's Avatar
Thats what all manual trannys do..Well at least chevys and hondas..And when i worked at mercedes they told me to ALWAYS put it into another gear before reverse..
Old Aug 22, 2007 | 08:20 PM
hatcht9x's Avatar
Default Re: (eda6)
thanks guys... but wutabout the "over-filled" tranny ? ? ?
Old Aug 22, 2007 | 08:24 PM
Jonknee's Avatar
Default Re: (hatcht9x)
over filed? doesnt the extra fluid leak out the breather hose on top
Old Aug 22, 2007 | 08:27 PM
hatcht9x's Avatar
Default Re: (Jonknee)
well.. filled over the "fill hole" near the bottom of the tranny.. or ids there another place to fill it?
Old Aug 22, 2007 | 10:32 PM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatcht9x &raquo;</TD></TR><TR><TD CLASS="quote">well.. filled over the "fill hole" near the bottom of the tranny.. or ids there another place to fill it?</TD></TR></TABLE>
You probably undid the drain bolt. The fill bolt is closer towards the firewall, above the passenger's side axle.
Old Aug 22, 2007 | 10:35 PM
90_Si's Avatar
Default Re: (93projectda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93projectda &raquo;</TD></TR><TR><TD CLASS="quote">Thats what all manual trannys do..Well at least chevys and hondas..And when i worked at mercedes they told me to ALWAYS put it into another gear before reverse..</TD></TR></TABLE>
My mustang is the same way, 90% of the time if I dont put it into another gear first reverse will grind.
Old Aug 22, 2007 | 11:03 PM
hatcht9x's Avatar
Default Re: (90_Si)
thanks guys!
Old Aug 22, 2007 | 11:27 PM
spaceman's Avatar
if you still grind then you would probably need to adjust your clutch cable.
good luck
Old Aug 23, 2007 | 12:04 AM
Rd91SiB18ls's Avatar
Did you check your clutch cable adjustment, How far off the floor is your
clutch pedal when it engages. You might tighten the cable a little.
Good luck
Old Aug 23, 2007 | 10:20 AM
hatcht9x's Avatar
Default Re: changing gear oil and in trouble! (Rd91SiB18ls)
yea the clutch cable does need to be adjusted.... also my Hasport shift linkage bushings are shot.. im juss goint to fab some solid ones THANKS ALOT GUYS.. i appreciate it!
black93octane
Transmission & Drivetrain
Oct 9, 2012 08:31 AM
wheelspk
Honda S2000
25
Oct 8, 2010 09:37 PM
EFresh
Honda S2000
Jul 21, 2010 08:39 AM
Scotty2H
Jun 27, 2008 12:00 AM
nek9
Aug 11, 2006 05:18 PM
