fan doesn't turn on!!!
Old Aug 22, 2007 | 04:52 PM
rohec04's Avatar
Default fan doesn't turn on!!!
i got a 98 prelude my radiator fan doesn't turn on, i connected it directly it works and i have a brand new fan activator switch so wha could be the problem?
Old Aug 22, 2007 | 05:15 PM
rohec04's Avatar
bump
Old Aug 22, 2007 | 05:55 PM
bluedlude's Avatar
Default Re: fan doesn't turn on!!! (rohec04)
im not 100% on this one, but on my girlfriends civic, i had to replace a temp switch that was under the distributor on the head. I see that the H has the same switch on it as well, so that would be my guess. it was $24 at advance auto.
Old Aug 22, 2007 | 06:02 PM
rohec04's Avatar
Default Re: fan doesn't turn on!!! (bluedlude)
yea i replaced that n it still dont wanna turn on the only way it does is when i turn the a/c on...
Old Aug 22, 2007 | 06:05 PM
bluedlude's Avatar
is there a fan relay?
Old Aug 22, 2007 | 06:16 PM
rohec04's Avatar
i havn't checked that how do i kno it doesnt work?
Old Aug 22, 2007 | 07:28 PM
rohec04's Avatar
bump
Old Aug 22, 2007 | 07:29 PM
bluedlude's Avatar
Default Re: (rohec04)
dont you have a helmes? throubleshoot it!
Old Aug 22, 2007 | 07:58 PM
SnlpeR's Avatar
the fan switch is the sensor where the upper radiator hose connects to the head
that first sensor with the green plug
Old Aug 22, 2007 | 08:17 PM
rohec04's Avatar
i changed the fan switch n the fan wont turn on it only turns un when i have the a/c on
Old Aug 22, 2007 | 08:25 PM
LukieLuc's Avatar
Default Re: (SnlpeR)
Isn’t the fan switch where the bottom radiator hose goes into the engine? Where the thermostat is located?
If you pull that plug of the switch and jump it with a paper clip or wire, while the car is on the "on" position, the fan should turn on, if it doesnt its your wires that are faulty, if it turns on the fan then its your fan switch thats not working properly
Also check your fan relay located in the "under hood" fuse box. When you jump the fan switch plug thats closest to the bottom radiator hose it should switch on with a clicking noise. If it doesnt thats the problem
check my old thread out
https://honda-tech.com/zerothread?id=2012417
Modified by LukieLuc at 12:40 AM 8/23/2007
Mitchell A.
Jun 5, 2016 02:16 PM
kirkland08
Mar 5, 2011 01:15 PM
tonysaur
Nov 17, 2007 11:39 AM
808MAUI
Feb 23, 2006 07:51 PM
wsiracerz
Jun 4, 2004 12:30 AM
