new here! timing belt question?
Old Aug 22, 2007 | 04:26 PM
Anomie's Avatar
Default new here! timing belt question?
ok i have a 1990 accord automatic! i'm pushing 103k and i was told i should really get my timing belt and water pump replaced! what gives? the guy who told me this is a friend but he was so serious about it. i's changing the timing belt at 103k really that important? the car run's perfect, besides a somewhat rough idle when i shift it into reverse.............. give me feedback thanks guys!
Old Aug 22, 2007 | 04:30 PM
Bruce Banner's Avatar
Default Re: new here! timing belt question? (Anomie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Anomie &raquo;</TD></TR><TR><TD CLASS="quote">ok i have a 1990 accord automatic! i'm pushing 103k and i was told i should really get my timing belt and water pump replaced! what gives? the guy who told me this is a friend but he was so serious about it. i's changing the timing belt at 103k really that important? the car run's perfect, besides a somewhat rough idle when i shift it into reverse.............. give me feedback thanks guys!</TD></TR></TABLE>
Do you want to have it break when u drive?
Yes it is important.
Old Aug 22, 2007 | 04:34 PM
2kdrift's Avatar
its important but also really expensive. yea it could break one day but you can always save up and do a motor swap when the time comes since that job is almost as much as a used H22 complete engine
Old Aug 22, 2007 | 04:35 PM
hondadude's Avatar
You should really get your timing belt,counter balance belt, water pump, cam seal, crank seal, counterbalance seal, and oil pump seal replaced.
Or wait till the belt strips some teeth off in a few thousand miles and pay out over $1000 for a junkyard motor swap
the rough idle in reverse could be a cracked motor mount ...check the front subframe "dogbone" mount at the top of it.
Old Aug 22, 2007 | 04:38 PM
Anomie's Avatar
Default Re: new here! timing belt question? (Bruce Banner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bruce Banner &raquo;</TD></TR><TR><TD CLASS="quote">
Yes it is important.</TD></TR></TABLE>
ok so it's important! so is this something a beginner can do own his own?
i only have experience doing brakes and oil change! gimme the low-down
i'm really on a budget!
&lt;-------- independent college student
Old Aug 22, 2007 | 05:04 PM
hondadude's Avatar
Check your IM ; and here is a link for you;
https://honda-tech.com/zerothread/1908944
kaoss_11
Aug 9, 2005 01:55 PM
Iomega01
Aug 2, 2005 08:12 PM
teler86
Jul 26, 2005 04:22 PM
2camsaam
Jul 30, 2003 12:20 PM
