safest whp for race gas?
Old Aug 22, 2007 | 01:21 PM
josh0407's Avatar
Default safest whp for race gas?
i know you can get some pretty high numbers with race gas, but what do you think a high number would be safely that would last a little while? only talking about running race gas at the track maybe once a month. thanks
Old Aug 22, 2007 | 07:29 PM
highmilehatch's Avatar
Default Re: safest whp for race gas? (josh0407)
Dude. Noone here is a mind reader. At least let people know what your setup is.
Old Aug 22, 2007 | 10:52 PM
Ls1 FD3s's Avatar
Default Re: safest whp for race gas? (highmilehatch)
lol, newb...
Old Aug 23, 2007 | 05:32 AM
sp00led's Avatar
Default Re: safest whp for race gas? (Ls1 FD3s)
Yea, screw messing with timing and turning up the boost. Race gas alone will make some serious powa!
Old Aug 23, 2007 | 06:14 AM
ndogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by josh0407 &raquo;</TD></TR><TR><TD CLASS="quote">i know you can get some pretty high numbers with race gas, but what do you think a high number would be safely that would last a little while? only talking about running race gas at the track maybe once a month. thanks</TD></TR></TABLE>
people push race gas to 800+hp so you can safely run 800hp on race gas.
Old Aug 23, 2007 | 06:31 AM
preludestud11's Avatar
Default Re: safest whp for race gas? (ndogg)
what kind of race gas? I know some setups are over 1100 hp on race gas.
Old Aug 23, 2007 | 08:49 AM
josh0407's Avatar
sorry i guess the post was pretty vague, not a noob just dont post much. the motor is a stock b16, do you think 400 whp is good with c16 at the track
Old Aug 23, 2007 | 08:54 AM
White Smoke's Avatar
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by josh0407 &raquo;</TD></TR><TR><TD CLASS="quote">sorry i guess the post was pretty vague, not a noob just dont post much. the motor is a stock b16, do you think 400 whp is good with c16 at the track</TD></TR></TABLE>
NO, race gas is going to reduce the chance of detonation but will not stop your pistons from melting. Race gas gives you a hotter more efficient burn. That on top of your stock cast pistons and 400hp leads to a blown motor. You should not go higher then 300HP on a stock motor and even then it's not going to last you very long.
Old Aug 23, 2007 | 09:49 AM
josh0407's Avatar
Default Re: safest whp for race gas? (White Smoke)
COOL. THANKS MAN
Old Aug 29, 2007 | 04:58 AM
quicksilver1689's Avatar
i ♥ snails
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">
NO, race gas is going to reduce the chance of detonation but will not stop your pistons from melting. Race gas gives you a hotter more efficient burn. That on top of your stock cast pistons and 400hp leads to a blown motor. You should not go higher then 300HP on a stock motor and even then it's not going to last you very long.</TD></TR></TABLE>]
dude you make no sense
Old Aug 29, 2007 | 04:59 AM
i ♥ snails
dont spread more bs around ht
Old Aug 29, 2007 | 05:28 AM
i my honda
Global Mod
Default Re: safest whp for race gas? (quicksilver1689)
OK
You bump up a week old thread to make this useless post.
Old Aug 29, 2007 | 08:06 AM
i ♥ snails
we dont need more tards on h-t im doin us a favor, race gas has a higher octane rating, burns slower, more resistent to pre ignition/detonation, some race gas has specific gravity and others can be very oxygenated. The purpose of race gas was not a hotter burning fuel with a more efficient burn lol.
Old Aug 29, 2007 | 08:23 AM
i my honda
Global Mod
Default Re: (quicksilver1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 &raquo;</TD></TR><TR><TD CLASS="quote">we dont need more tards on h-t im doin us a favor, race gas has a higher octane rating, burns slower, more resistent to pre ignition/detonation, some race gas has specific gravity and others can be very oxygenated. The purpose of race gas was not a hotter burning fuel with a more efficient burn lol.</TD></TR></TABLE>
First off I never said it was the "purpose" of the fuel but it certainly DOES burn hotter AND more efficiently. Anytime you raise the octane rating of fuel it is going to burn more efficiently. Not one thing I said was inaccurate so GFU.
Oh and please tell me how the gas itself is more resistant to detonation. It's the way it oxidizes and burns not the gas itself.
Old Aug 29, 2007 | 08:26 AM
i ♥ snails
straight from sunoco race fuels
Most people think the higher the octane rating the hotter the fuel burns. It's actually the opposite, the higher the octane rating the slower the fuel burns. Thus enabling the tuner to lean the fuel mixture down because they are now dealing with a more controlled burn rate. Thus making more power. Also, each motor requires a different ratio depending on modifications. So you don't always have run straight race fuel.
Old Aug 29, 2007 | 08:30 AM
i my honda
Global Mod
Yes it takes longer to burn and requires less fuel. But when COMPARING it to a lower octane rating fuel, the same amt of the lower octane will produce a lower temp compared to the same amt of higher octane.
Simple test, take a cap full of gas and set it on fire. Fell the amt of heat that comes off of it. Now take a cap of Jet A (jet fuel) and light it on fire. Let me know which makes you feel all warm and fuzzy inside. lol
Old Aug 29, 2007 | 08:37 AM
i ♥ snails
ok ill go try that right now, hope i dont burn my house down. LOL
Old Aug 29, 2007 | 08:39 AM
i my honda
Global Mod
He is talking about C16...
Old Aug 29, 2007 | 08:50 AM
twkdCD595's Avatar
Default Re: (White Smoke)
jet fuel... that is the mad tyte jaydeem racer fuel huh.... jet fuel make u supa dupa fas...
also when you say race gas burns "more efficiently" or burns "hotter", I asume you are trying to reference the energy volume of said fuel?
EDIT: correction, typing fast at work and owned by misuse of word.
Modified by twkdCD595 at 4:20 PM 8/29/2007
Old Aug 29, 2007 | 12:13 PM
liam821's Avatar
Default Re: (twkdCD595)
its not how much power you make, its how much boost you run...
Old Aug 29, 2007 | 12:17 PM
liam821's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 &raquo;</TD></TR><TR><TD CLASS="quote">avgas make u supa dupa fas... </TD></TR></TABLE>
avgas is basically 100 octane leaded fuel - ive used it with a mix of 91 in my car before with good results. However, these days, avgas is really no cheaper then 110 octane race fuel and therefore no point to use it. If you do though, make sure if you use 100LL avgas ie the low leaded version, which still has a ton of lead, but less then the other stuff.
All you ever wanted to know about avgas and more: http://en.wikipedia.org/wiki/Avgas
Ah the days of $2 a gallon avgas...
liam
Old Aug 29, 2007 | 12:35 PM
fmfkid250's Avatar
There is a local kid (chime in) making 407whp on a stock B16 and has been running pretty good for a couple months 11.0 on slicks 11.8 on street tires PWS trim
i think this was on 50% race gas 112 and 50% pump
Old Aug 29, 2007 | 01:17 PM
twkdCD595's Avatar
Default Re: (liam821)
I am a bit familar with it, thank you.
For reference I was refering to actual aviation fuel and should not have used the term avgas. White smoke refered to Jet A for his proposed test which is kerosene/ paraffin oil-based based jet fuel and what I was basing my comment on... good for turbines or maybe deisels but not gasoline piston engines.
I will correct my post, fast typing at work owned me... I stand corrected.
Though I will add that actual avgas is not the best source for a race fuel/ octane increase either imo, and I would say it is more like leaded gas from 1960 than anything. The octane is not rated by the same system that rates automobile fuel (although it is somewhat similar)... so 100LL is not quite the 100 octane you might believe it is. You were basically just adding a **** ton of lead with very little octane increase by a automobile standard of rating fuels. Also avgas has high levels of aromatics which result in poor throttle responce generally in piston engines, which is not a major concern for a plane but is an automobile. It was formulated for high altitude so low altitude use results in a lean condition without some added fueling compensation. Avgas has different lubricating properties and additives that I could go on about boring you but I will just cut to the chase and say its better to seek octane elsewhere imo.
If you want just add some tetra-ethyl lead to your fuel and you can achieve higher octane ratings with the same 1950-60's approach that is used for avgas... but fair warning it is highly toxic.
I know someone will say well I used it and it worked... well congrats, that does not make it good.
Sorry seems I am straying off topic... back to it.
Modified by twkdCD595 at 5:34 PM 8/29/2007
Old Aug 29, 2007 | 06:28 PM
Jay_Sensing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 &raquo;</TD></TR><TR><TD CLASS="quote"> White smoke refered to Jet A for his proposed test which is kerosene/ paraffin oil-based based jet fuel and what I was basing my comment on... good for turbines or maybe deisels but not gasoline piston engines.
Thank you for saving me the trouble of typing it. I work in aviation for a living and get so tired of hearing people refer to "jet fuel" like it's something special. More like dirty diesel.
racin jasin R
Apr 18, 2007 10:16 PM
B-A-N-A-N-A-S
May 20, 2005 11:52 PM
sloweredcivic
Feb 8, 2004 08:35 PM
wm5holla
Feb 1, 2003 08:49 AM
