changing throtle cable out on eg to a gsr one.
first of all u have a b16 or b18 swap?? and it is very easy.first of all check if there is a throttle cable bracket on the intake manifold.if not, then u need to get the right one,eg d series wont work.first of all disconnect the throttle cable from the gas pedal and go to your engine bay and pull it off from the firewall (not pull when u are inside the car),and when u get the new throttle cable.just reverse what u did to remove the d series one.good luck.
and for b16a swap u want to use 94 up integra LS throttle cable not GSR.cause i just swapped mine a week ago.good luck
why would you need to change th cable for? a gsr will work on a d series but not on a LS, b16 or type r. you would need a type r cable and bracket
EG_SICKZ
Mar 17, 2010 09:53 AM
eggsi619
Jun 29, 2009 11:14 AM
