Need help with Skunk2 coils and Koni Yellow
Banned
Do you guys know if the Skunk2 coils need a special adapter for the Koni Yellows? If so, where can I get them?
Haven't heard this before, but just check with Skunk2 to be sure. I know people do run those with the Koni's though. I would personally prefer the Ground Controls if I had to chose a coilover sleeve though and not a full threaded coilover, but the Skunks aren't that bad.
You do not need any adapters if I'm understanding the question correctly. What are the numbers on the spring? If they end in 10, you'll likely need to have the shock custom valved to handle the 500# spring rate.
STOCK_SOHC_DX
Suspension & Brakes
42
Jul 5, 2013 02:54 PM
