crx window problem
Old Aug 22, 2007 | 07:29 AM
wmertz187's Avatar
Default crx window problem
I got my window BACK on the track, but are there any bolts to tighten to secure the window in the actual tracking mounts that it sits in, because everytime i get them situated i try to use it and it falls right back off
Old Aug 22, 2007 | 10:54 AM
Its me DUB's Avatar
Default Re: crx window problem (wmertz187)
Yes, there should be two bolts that hold the window onto the regulator. The window should have two plastic pieces attached to the bottom of it, and these sit on the regulator and the bolts go through the plastic pieces to adjust/tighten.
When I was having a window regulator issue with my previous CRX, I took apart the door panel of the working window and compared the two. Do that and you can see what's missing or messed up.
Modified by Its me DUB at 12:14 PM 8/22/2007
Old Aug 22, 2007 | 08:51 PM
wmertz187's Avatar
Default Re: crx window problem (Its me DUB)
see i was looking at that, but i believe the rear one is stripped.. so now what? i guess previos owner had the same problem and over tightened them.. so i guess ill take it apart tomorow and try to get a replacement bolt
Old Aug 23, 2007 | 06:40 AM
Its me DUB's Avatar
Same thing happened to my previous rex. You can use a tap n die kit, and re-thread the hole. I didn't have one at the time though, so I just used a slightly larger diameter bolt and it held tight. It's not something you'll be removing a lot, so if you get it right, you could also just epoxy the bolt into the right place....but that's a bit more permanent.
phong3992
20
Mar 4, 2011 01:29 AM
ndrew2505@yahoo.com
Oct 30, 2008 12:47 AM
tx95excoupe
11
Sep 14, 2007 05:43 AM
Devilry
Nov 22, 2004 07:35 PM
