PLX wiring
Old Aug 22, 2007 | 12:51 AM
DCxMagus's Avatar
Default PLX wiring
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">yel/blk - A25 - 12V switched
org/blk - A6 - O2 heater control
grn/wht - D22 - sensor ground
wht/red - D14 - O2 signal wire
originally posted by 98vtec in another thread </TD></TR></TABLE>
for easy searching
Also ELD is D10 if your going to use that as the output for Hondata S300
Modified by DCxMagus at 8:42 PM 8/22/2007
Old Aug 22, 2007 | 03:22 AM
lude98SH's Avatar
Default Re: PLX wiring (DCxMagus)
what ecu are you using ? How many o2 sensors are you running ?
Old Aug 22, 2007 | 10:32 AM
PrecisionH23a's Avatar
Disable your stock 02 in hondata and run the white wire to d14 on the obd1 ecu. You may need to play with your gain settings or voltage settings.
Old Aug 22, 2007 | 02:28 PM
DCxMagus's Avatar
Default Re: PLX wiring (lude98SH)
P28 w hondata S300
I have the wideband welded into it's own bung so Ihave the 2 stock sensors and then the wideband in there atm.
just need to know where to get power from for the wide band. as non o the ECU pin outs have a 12V ignition power listed at any of the pins.
Old Aug 22, 2007 | 02:30 PM
lude98SH's Avatar
get a pinout of the ecu and you should be good to go
Old Aug 22, 2007 | 02:38 PM
DCxMagus's Avatar
I'm looking at the pin out but none of the pins read as a 12v ignition power source on it. Using the one in the FAQs
EDIT A25 and B1 both say PGM-FI main relay(power) would that be ok to use as a power source?
Old Aug 22, 2007 | 02:44 PM
lude98SH's Avatar
Old Aug 22, 2007 | 02:45 PM
DCxMagus's Avatar
awesome thank you very much I just wasn't sure if A25 was switched or not
Treyschls
Dec 11, 2014 07:49 PM
TB123
Engine Management and Tuning
27
Dec 21, 2008 04:19 PM
DaiJekBok
May 24, 2007 08:51 PM
5thGenFanatic
Aug 25, 2005 04:08 AM
