clutch pedal problem
I have a 1998 Honda prelude. Recently, I've been having trouble with my clutch pedal. When I press down on my clutch, it won't come back up. I would manual pull back the clutch pedal slightly, and it would bounce back to normal height, then it be working just fine again. I would experience this problem, about 1 to 2 times a week. I've checked my reservoir, and it's still full. There doesn't seem to be a leaks by the master cylinder. What could be the problem?
try bleeding the system, cause maybe you have a little air in the line. If that doesn't help, you'll need to change your master and slave cylinder. It's best to change both at the same time since it'll save you time and headach in the long run. Won't have to bleed the system twice
