REALLY Slow Cold Start, Misfire Idle - Whats The Problem?
Old Aug 21, 2007 | 10:03 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Default REALLY Slow Cold Start, Misfire Idle - Whats The Problem?
Ive got an obdo b16 in my car, ran good other than the misfire before I swapped the clutch.
If the car has been sitting for 3+ hours and completely cools down, the thing will take 5-7 seconds to start, it cranks real easy and its turning over and getting great power from the starter but just wont kick, then when it does, its not instant, it takes a second.
If the car is cold and started up there is also a very audible misfire, the engine stumbles if you try and push the gas and ESPECIALLY if you try and drive it.
2 minutes of driving and the cars mint.
1 problem I know of for sure, is I spotted to uncoonected wires, its a solid green wire with a female connector and a yellow white with a male connector, there over by the intake by the wires are pretty long I dont remember where they came from. Are thye possibly on the back of the block?
For my misfire, when I bought the car, I changed the plugs oil and air filter thats it, the misfire kinda gradually came on and now its just pissing me off. Could it be my rotor in the dizzy possibly? Suggestions?
Thanks guys
Old Aug 22, 2007 | 05:36 AM
PINKS's Avatar
Default Re: REALLY Slow Cold Start, Misfire Idle - Whats The Problem? (PINKS)
Old Aug 22, 2007 | 10:01 PM
PINKS's Avatar
Old Aug 22, 2007 | 10:49 PM
Ls1 FD3s's Avatar
do wires/cap/rotor. Theres a weak link in there somewhere, new plugs only band aided it for a bit. Also, let her warm up a bit! I remember my 83mm gsr/je slugs took a good 5 mins of me peddalin and restarting it till it would idle on its own, haha. colder heat range plugs will have an affect like that as well, or fowled ones for that matter, lol.
Old Aug 23, 2007 | 06:32 AM
PINKS's Avatar
Default Re: REALLY Slow Cold Start, Misfire Idle - Whats The Problem? (Ls1 FD3s)
Alrighty I guess I might go pick up some plug wires aswell then
Old Aug 25, 2007 | 12:29 AM
Ls1 FD3s's Avatar
any updates?
Old Aug 25, 2007 | 04:55 AM
RACEPAK's Avatar
forgot a ground on the termo housing?
Old Aug 25, 2007 | 06:11 AM
Ls1 FD3s's Avatar
Default Re: REALLY Slow Cold Start, Misfire Idle - Whats The Problem? (RACEPAK)
yea that little son of a bitch will cause trouble too!
Old Aug 25, 2007 | 06:44 AM
PINKS's Avatar
New cap, rotor and battery and weve got a perfectly running car!!
chrisfromsrq
Jul 21, 2009 08:41 AM
95goldSE
Sep 12, 2007 03:38 PM
PINKS
Aug 24, 2007 08:52 PM
PINKS
13
Aug 23, 2007 09:49 PM
PINKS
Aug 23, 2007 06:31 AM
