Bumper pole install
Just received my bumper pole and switch today, is it possible to wire it up without a harness and relay? I have four wires: red, black, yellow w/ red, and yellow w/ white. The red and black light up the pole. When the yellow w/ white connected to positive and the yellow w/red connected to negative it moves up. AND then visa versa to make it go down. How would i go about hooking this up to a switch that would make it go up and down. thanks - josh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john666 »</TD></TR><TR><TD CLASS="quote">your going to need a relay buddy..
check the12volt.com</TD></TR></TABLE>
theres no other way???
for that site what do i look for? thanks
I believe you are reffering to the parking pole...if so try this link you may find what you are looking for...**EDIT** read your post through, and yes you will need a relay
https://honda-tech.com/zerothread?id=2042544
i read that post; very useful thanks
Modified by Jdm_Eg686 at 12:38 PM 8/22/2007
99CivicSiBrian
13
Apr 16, 2006 05:19 PM
