93 Si h23 turbo help
Old Aug 21, 2007 | 09:04 PM
pk93perh23ny's Avatar
Default 93 Si h23 turbo help
I have a 93 Si with an H23A1 non V-Tec with 140k, I want to Boost it. What are all the nesessery engine preperations before instaling a turbocharger? Can anyone help me out?
Old Aug 21, 2007 | 09:10 PM
Hawkze_2.3's Avatar
Default Re: 93 Si h23 turbo help (pk93perh23ny)
Sure, read the Prelude FAQs, the Official Prelude turbo thread and the Forced Induction forum FAQs.
Old Aug 21, 2007 | 09:11 PM
dtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pk93perh23ny &raquo;</TD></TR><TR><TD CLASS="quote">I have a 93 Si with an H23A1 non V-Tec with 140k, I want to Boost it. What are all the nesessery engine preperations before instaling a turbocharger? Can anyone help me out?</TD></TR></TABLE>
Sleeve your block, and replace all internals with forged parts, then you'll be good to go.
Old Aug 21, 2007 | 09:15 PM
Acidcrakker's Avatar
Default Re: 93 Si h23 turbo help (dtec)
Okay Im sorry this might be a retarded question, but when you say replace with forged parts do you mean like the pistons and camshaft and stuff like that. Are those the forged parts you speak of?
Old Aug 21, 2007 | 09:25 PM
Hawkze_2.3's Avatar
Default Re: 93 Si h23 turbo help (acidcrakker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">Okay Im sorry this might be a retarded question, but when you say replace with forged parts do you mean like the pistons and camshaft and stuff like that. Are those the forged parts you speak of?</TD></TR></TABLE>
Pistons and rods.....no forged cams...
Old Aug 21, 2007 | 09:35 PM
dtec's Avatar
Just the block's internals.
Old Aug 21, 2007 | 09:58 PM
Sleeve the block? explain.
Old Aug 22, 2007 | 04:04 AM
spoolinlude's Avatar
I live under a rock
Use the search function, and search for FRM sleeves or h22/h23 sleeves
basically, stock h-series engines don't hold up well to turbo applications. Especially ones with 140K....
Get your learn on for a few months, then go for it.
Old Aug 22, 2007 | 10:08 AM
DfwBB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pk93perh23ny &raquo;</TD></TR><TR><TD CLASS="quote">Sleeve the block? explain.</TD></TR></TABLE>
spoon feed FTL!!!
Old Aug 22, 2007 | 10:29 AM
PrecisionH23a's Avatar
140k is a ton of miles to throw a turbo on. A Compression test and cylinder leak-down test will definetely need to be done before you think about throwing a turbo on that stock motor.
Old Aug 22, 2007 | 12:11 PM
dtec's Avatar
Your car has a lot of miles, so if you want a reliable turbo car, you'll need to rebuild the bottom end of your motor. Your stock sleeves won't be able to consistently handle the power of a turbo application, so you will need to "resleeve" your block's cylinders with a stronger material. And since you have the block open, you might has well replace the other internals with stronger forged parts, like pistons, etc...
The whole thing will probably cost you around $2k, but it's well worth it because you'll car will be able to handle a lot of power reliably.
Old Aug 22, 2007 | 12:35 PM
98vtec's Avatar
moderator emeritus
the sleeves arent what is weak.
Old Aug 22, 2007 | 01:32 PM
dtec's Avatar
Default Re: 93 Si h23 turbo help (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">the sleeves arent what is weak.</TD></TR></TABLE>
They're not, but they weren't made for turbo. The stock FRM sleeves will handle 8-10psi fine, but the question is how long? The life of the engine will go down considerably.
Old Aug 22, 2007 | 01:59 PM
98vtec's Avatar
moderator emeritus
not because of the sleeves. It's the rings that will go out way before the sleeves do. Especially the open deck blocks with all the extra cooling they have being surrounded by coolant.
i have yet to see someone crack a stock FRM sleeve. And if it has been done i would like to know the power levels which was reached.
Old Aug 22, 2007 | 02:06 PM
nonvteclude's Avatar
correct. FRM is much stronger than people give it credit for. the piston ring lands are the weak points. but due to the frm you cant just slap any old piston in there. OP search around and do alot of reading you will be all the better for it.
Old Aug 22, 2007 | 06:43 PM
RA102725's Avatar
Default Re: 93 Si h23 turbo help (nonvteclude)
pm'ed you with some help
coojoe59
Jun 6, 2008 05:57 AM
monkeyboy313@hotmail.com
Apr 4, 2007 11:48 AM
Gsr_Rob
Feb 19, 2005 03:43 PM
preludesi93-arg
Feb 1, 2005 05:25 PM
john cusack
Apr 16, 2003 06:27 AM
