1994 civic vx beiing swapped with 01 gsr.
Old Aug 21, 2007 | 06:04 PM
kajay1972's Avatar
Default 1994 civic vx beiing swapped with 01 gsr.
i have a donor car (2001 gsr) what parts do i have to use from the obd2 gsr to put in my civic?
is my wire harness good for this swap? or do i use the gsr?
gsr ecu or vx ecu?
can i convert this obd2b motor to a obd1?
is there any rewiring involved?
thanks for any advice.
Old Aug 21, 2007 | 06:10 PM
crazyguy's Avatar
Default Re: 1994 civic vx beiing swapped with 01 gsr. (kajornklin)
u will need harness convertion from obd2 to obd1 and u need to use gsr ecu.shift linkage..axles..mounts..and u will need a LS throttle cable cause gsr wont fit..
pretty much just drop in ..and for the ac parts...there are various options.lmk what kind of ac set up u want to use and i will give u some idea.
Old Aug 21, 2007 | 06:14 PM
kajay1972's Avatar
Default Re: 1994 civic vx beiing swapped with 01 gsr. (crazyguy)
i have ac set up in my civic already and the integra has one too. im not able to use my vx throttle cable?
Old Aug 21, 2007 | 06:18 PM
crazyguy's Avatar
no.u wont be able to use your vx cable.i tried that before and for the ac set up.i would stay with d series ac set up and get a del sol vtec or crv ac braket and reuse the d series ac compressor thats the easiest way.
but i use different set up caz i cant find the del sol vtec ac bracket in such a short time. so i use the d series pipe and condensor and fan but i use jdm p30 ac bracket and usdm gsr ac compressor,just need to modiy the h and L pressure pipes a bit.
Modified by crazyguy at 9:22 PM 8/21/2007
USDMCIVICHATCH's Avatar
you should use the gsr throttle cable cuz that is the ONLY one that will fit
Old Sep 7, 2007 | 09:19 PM
laocivic's Avatar
you pretty much have to use everything from the gsr. i mean mounts, axles, shift linkage, ecu. you can use the vx harness, but you gotta wire it for vtec. like CRAZYGUY sed i gotta buy a conversion harness for the ecu cuz your car is obd1 and the ecu is obd2.
Old Sep 7, 2007 | 09:51 PM
CapnKrunch's Avatar
Default Re: 1994 civic vx beiing swapped with 01 gsr. (laocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laocivic &raquo;</TD></TR><TR><TD CLASS="quote">you pretty much have to use everything from the gsr. i mean mounts, axles, shift linkage, ecu. you can use the vx harness, but you gotta wire it for vtec. like CRAZYGUY sed i gotta buy a conversion harness for the ecu cuz your car is obd1 and the ecu is obd2.</TD></TR></TABLE>
You don't have to wire up VTEC on a VX harness.
Old Sep 7, 2007 | 09:53 PM
laocivic's Avatar
Default Re: 1994 civic vx beiing swapped with 01 gsr. (CapnKrunch)
oh my fault...its the other way around.. vx's are prewired
raidacaipo
12
Jul 11, 2008 06:57 PM
lPat
Aug 21, 2007 03:14 PM
Stripped Honda
Jun 15, 2005 07:05 PM
