I love my SMSP header - Got tuned today!
Old Aug 21, 2007 | 05:54 PM
luder94-ChrisA's Avatar
Default I love my SMSP header - Got tuned today!
Several months ago, I made my tuning appointment for today at Evans Tuning. I had decided to ditch my VAFC & get a hondata system (I traded some old stock parts for a P28 with S100) Unfortunately, my custom-fabbed 2.5" lca exhaust (using two magnaflo 2.5" core resonators) won't be ready until next week, so I had to tune with a high-flow cat & a 60 mm exhaust. However, I was pleasantly surprised by the results....
I have a basic set-up:
JDM H22 - 60k miles
Iceman intake (converted to short-ram)
IAB's eliminated (made a homemade blactrax spacer by removing all components of butterflys & filling holes)
Removed balance shaft belt
Removed A/C & C/C
Still running PS - but using AEM pulley
SMSP 4-2-1 header
SMSP 2.5" Hi-flow cat
Thermal R&D stealth exhaust
Dynapack Dyno 3000
Temp = 71 degrees
Humidity = 80%
Results:
Peak HP = 195.8
Peak Torque = 144.5
After finishing tuning, peak power was slightly lower (193.5) but more area was under the curve up high. She makes nice linear power up to ~7500 rpm.
Jeff was impressed with how strong the motor is (& so am I). The SMSP header made all the difference! I'll have the graphs up tomorrow after he emails them to me.
Old Aug 21, 2007 | 06:18 PM
mgags7's Avatar
Thats awesome dude, great numbers
W/O PS it would have been 200....and if you get another shot at a pull on the dyno try running the intake full length, that should pick up a few ponies.
7500rpm is great on stock cams too, most setups die around 7200.
Old Aug 21, 2007 | 06:48 PM
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
7500rpm is great on stock cams too, most setups die around 7200.</TD></TR></TABLE>
Actually, it stops making power around 7250 but plateaus until it stops to drop at 7500 rpm. I'll still shift at 7500-7800 rpm (on the track), just so I don't drop the rpms too low.
Old Aug 21, 2007 | 09:38 PM
98vtec's Avatar
moderator emeritus
Default Re: (luder94-ChrisA)
sounds about like my motor, i bet it feels great. Especially with an evans tune. i wish my tunes could be backed with his kinda knowledge.
Old Aug 22, 2007 | 03:43 AM
PirateMcFred's Avatar
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">I bet it feels great.</TD></TR></TABLE>
Where's the torque though? it seems like a lot of JDM H22s are making around 155-160wtq...
Get the graphs up please. What exhaust setup did you have before?
Pirate
Old Aug 22, 2007 | 03:51 AM
AndyD's Avatar
Default Re: I love my SMSP header - Got tuned today! (luder94-ChrisA)
Whoa! That's awesome, Chris! Can I have my header and ECU back now? j/k
My goal was 200whp without cracking the engine open. You are almost there!!
Oh, there is a Porsche DE at Summit in Nov. 3-day event. You should come down for that if you can!
Old Aug 22, 2007 | 03:56 AM
AndyD's Avatar
Default Re: (PirateMcFred)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">
Where's the torque though? it seems like a lot of JDM H22s are making around 155-160wtq... </TD></TR></TABLE>
With only bolt-ons? I thought stock they made ~140wtq.
Old Aug 22, 2007 | 03:59 AM
94vtirozguy's Avatar
welcome to the satisfied SMSP crew
Old Aug 22, 2007 | 07:58 AM
TylerC161's Avatar
Im excited about getting my header. currently mine is stock, i made 183whp and 162wtq, im hoping to hit 200whp and at least 170tq with my ESP header.
Old Aug 22, 2007 | 08:12 AM
NirVTEC's Avatar
Default Re: (TylerC161)
Well, again comparing dynos is a tough world.....I just don't know how that DynoPack number would convert to a Dynojet.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">
Pirate</TD></TR></TABLE>
You usually don't see over 150 unless there are a/m cams involved. But I have seen stock cammed H22's making mid 140's with crappy headers on there.
I don't think removing the p/s would make that much of a difference as far as straight line power which is what a dyno is.
I say get some ET's and we'll really know what the setup can do!
Old Aug 22, 2007 | 08:42 AM
117's Avatar
117
I need to check my graphs, but I thought mine was over 150WTQ on stock cams. I'm thinking 154WTQ, but I could be wrong. Maybe it's 144WTQ.
Old Aug 22, 2007 | 09:07 AM
Default Re: (117)
Here's the graph from the final run. Ended up with slightly less power - 193 but a better curve. Still not as much torque as I would hope for. But it still is a lot of fun on the track!
I'm wondering if the iab delete or the exhaust set-up might have something to do with the torque curve. It was dynoed with a 2.5" hi flow cat that dumped into a 60mm catback (Thermal Stealth). It's not a smooth transition. 2.5" pipe into 60mm. I just had a 2.5" lca exhaust with a 2.5" resonator made (in place of the cat), so I will hopefully get that set-up dynoed later this year.
Old Aug 22, 2007 | 09:30 AM
CAN97SH's Avatar
Resident Hoser #1
Community Builder
Community Influencer
So minus the other mods you have done, what kind of TQ and HP gains did you see out of the SMSP?
Old Aug 22, 2007 | 10:34 AM
A Blue Lude's Avatar
Default Re: I love my SMSP header - Got tuned today! (CAN97SH)
For a JDM H22 with no BS and those mods your TQ seems lowish - but on the other hand it shows how well the SMS carries power on your engine, given how much power you made out of it.
I was only getting 180s out of 140tq, with similar stuff on my US H22.
Old Aug 22, 2007 | 10:56 AM
Chukkie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TylerC161 &raquo;</TD></TR><TR><TD CLASS="quote">Im excited about getting my header. currently mine is stock, i made 183whp and 162wtq, im hoping to hit 200whp and at least 170tq with my ESP header.</TD></TR></TABLE>
Stock? How is that?
Old Aug 22, 2007 | 11:03 AM
TylerC161's Avatar
Default Re: (Chukkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chukkie &raquo;</TD></TR><TR><TD CLASS="quote">
Stock? How is that?</TD></TR></TABLE>
I meant I have a stock header. Pretty much I have CAI, IM, Flywheel, Exhaust.
I dont know what people are talking about not making more then 150tq, as I said i made 162. Stock cams and gears too.
Old Aug 22, 2007 | 11:05 AM
mgags7's Avatar
on a dynojet 228 or a dynapack or something?
you would never make anywhere near 160wtq on stock cams on a dynojet228. ever.
Old Aug 22, 2007 | 11:17 AM
CAN97SH's Avatar
Resident Hoser #1
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">on a dynojet 228 or a dynapack or something?
you would never make anywhere near 160wtq on stock cams on a dynojet228. ever.</TD></TR></TABLE>
lol, is there even a real way to calculate true TQ and HP numbers¿ Every dyno is different!
Old Aug 22, 2007 | 11:22 AM
TylerC161's Avatar
Default Re: (CAN97SH)
It was done on a Dynojet.
My dynograph says "Dynojet WINPEP7"
"Run conditions: 64*, 29.54Hg, SAE: 0.98"
(excuse me on the next, i was wrong in my numbers)
"Max power = 182.62whp Max torque = 163.76"
Old Aug 22, 2007 | 11:25 AM
mgags7's Avatar
you should consider the possibility that you got an sir spec-s or an atr with the dual runner IM engine with your swap.
Do you have a pic of the graph? Is that one little freak peak where it missed or is it up there for a while?
Old Aug 22, 2007 | 11:26 AM
TylerC161's Avatar
I'll make a new thread. dont wanna clog this one.
Old Aug 22, 2007 | 09:19 PM
Huh? My old H22 made almost 161wtq on stock cams. With IAB it made a flat 140wtq up to VTEC on a Dynojet model 248C. On the stock header and P13 ECU it made 150wtq peak.
Pirate
Old Aug 23, 2007 | 09:57 AM
NirVTEC's Avatar
All dynos read different...
People need to stop comparing them.
I have never seen a stock cam H22 break 145tq on the dyno I made 156tq with cams. And that was over 10 different Preludes....
Ive also never seen a stock cam Prelude break 180whp on the same dyno I made 204whp with JUNs.
Old Aug 23, 2007 | 10:16 AM
Chukkie's Avatar
Default Re: (:=:NirVTEC:=:)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by :=:NirVTEC:=: &raquo;</TD></TR><TR><TD CLASS="quote">All dynos read different...
Ok...so maybe not comparing...but from experience it is odd to see those numbers from a stock cam H22...I haven't seen ten (in person) maybe only 4 or 5...but those numbers never came up.
Old Aug 23, 2007 | 10:49 AM
NirVTEC's Avatar
Ok...so maybe not comparing...but from experience it is odd to see those numbers from a stock cam H22...I haven't seen ten (in person) maybe only 4 or 5...but those numbers never came up.</TD></TR></TABLE>
which ones? The ones I listed?
This is the same dyno that was breaking "B" babies hearts clicking high 130's-low 140's from bolt on B18's.
