Someone help me w/ this ignition problem!!
Old Aug 21, 2007 | 05:42 PM
VN712's Avatar
Default Someone help me w/ this ignition problem!!
Hey everyone!
I've just replaced the ignition switch on my 93 dx coupe and now my key won't even turn over (I cant move it up to I, II, etc.). And when I connect the battery to get power, all the instrument icon lights up. Wassup with that? Or is my cylinder messed up and I need a new one? Am i missing a step to doing the installing?
I've searched around, and someone said that I need a new key from Honda or something? What am i missing here?
Help me guys, the car has been sitting for 2.5 weeks already!
Thanks for any tips/comments.
Old Aug 21, 2007 | 05:44 PM
typeoneeg6's Avatar
Default Re: Someone help me w/ this ignition problem!! (VN712)
just the switch or the whole ignition cylinder?
Old Aug 21, 2007 | 05:51 PM
VN712's Avatar
Just replaced the switch.
Old Aug 21, 2007 | 07:33 PM
VN712's Avatar
Someone had to have been in this situation before.
Old Aug 21, 2007 | 07:47 PM
gsrhatch2356's Avatar
if it dosent turn it is bad plain and simple and if the lights light up when you connect battery you either have the wires in the wrong spot. or come to think about it when you did this you just pulled the white piece off the end and replaced the ignition part right. well pull that white part with wires back off and verify that you can turn the key then see if it is even possible that if you have it 180 out so that when the key is off the switch or white piece is already set to the third position.
Old Aug 22, 2007 | 10:22 AM
VN712's Avatar
Default Re: Someone help me w/ this ignition problem!! (gsrhatch2356)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrhatch2356 &raquo;</TD></TR><TR><TD CLASS="quote">if it dosent turn it is bad plain and simple and if the lights light up when you connect battery you either have the wires in the wrong spot. or come to think about it when you did this you just pulled the white piece off the end and replaced the ignition part right. well pull that white part with wires back off and verify that you can turn the key then see if it is even possible that if you have it 180 out so that when the key is off the switch or white piece is already set to the third position.</TD></TR></TABLE>
Thank you
Old Aug 22, 2007 | 11:50 AM
mgags7's Avatar
was that your problem?
the key not turning could have been the steering lock holding it....
Old Aug 22, 2007 | 11:54 AM
fmrprojects's Avatar
Default Re: (VN712)
you didnt line up the groove correct when you put it on. take it out and make sure it lines up
Old Aug 22, 2007 | 02:34 PM
VN712's Avatar
Default Re: (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">you didnt line up the groove correct when you put it on. take it out and make sure it lines up</TD></TR></TABLE>
problem fixed. thanks guys
naperil
Jul 15, 2015 06:15 PM
RecklessEJ
Sep 11, 2011 03:06 PM
racingcrx
Jul 4, 2008 01:07 PM
benmyfriend
Dec 4, 2005 09:54 PM
BlkGSR
Mar 7, 2004 06:28 AM
