scratching noise coming from transmission
so this scratching noise occcured yesterday while entering the freeway... as i entered the freeway yesterday i shifted into second and i hear this scratching noise so i took it out of gear and then it wont let me in gear anymore but after a cople of tries it let me in gear.. but everytime i shift down to any gear the scratching noise will come back.. so i get on the regualr streets and the scratching noise stops..now it only happens when im in first gear getting ready to put the car in motion.. btw the car is a b16 swap wit a gsr transmission.. any help would b appreciated
There goes another B16 tranny. I guess people are right when they say these trannies are notorious for breaking. But yes, like everyone else said, tranny fluid change. Don't go for the cheap stuff, just go to Honda, buy 2 qts of Honda MTF and see where things go from there.
Could possibly be a clutch issue. You might be hearing chatter, and the clutch could be worn down so far that the vents are gone, and the disc is getting sucked onto the flywheel because the vents to release the vacuum created by the flywheel/clutch turning are now gone, resulting in harsh/erratic shifting.
Was there corrosion on the input shaft when the tranny was put on? This can also cause the disc to bind on the shaft, and prevent it from releasing properly as well.
yea its more like a chattering noise... i can feel it on the clutch pedal when im releasing the clutch.. but il change the tranny fluid and we'll see if thats the problem before i go on to the clutch and hope that its not the tranny
yeah my old car used to do the same thing .. except it was in every gear .. once youd get up to a certain rpm it would start making a scratching/scraping noise. But if you take the rpms up slowly you wont hear the noise. I took it to a transmission shop and they told me that the bearing inside the transmission needed to be replaced. The bearings itself would cost somewhere around $200 just to buy.
JDM2317
Apr 21, 2010 04:30 PM
corcoran_chris
Dec 11, 2008 10:07 AM
