White or Black roof?
Old Aug 21, 2007 | 09:52 AM
SunnyTO's Avatar
Default White or Black roof?
Hey i'm currently doing the $50 paint job for my car right now, and i'm not sure if i should paint the roof black. I want to do this because iw ill be getting a carbon fiber hood in a few months, and was wondering what do you guys think for now a black hood on a white 4th gen prelude?
I dont think i've seen any done like that.
Old Aug 21, 2007 | 09:54 AM
IIVIIoOkY's Avatar
Default Re: White or Black roof? (SunnyTO)
if you wanna get an idea of what it looks like there is a 5th gen owner in the prelude picture thread that has it done.
Old Aug 21, 2007 | 10:05 AM
M@'s Avatar
M@
That might keep you warmer in the winter time +1 for a usefull mod
Old Aug 21, 2007 | 10:14 AM
viper_boy403's Avatar
thats what im gonna do on my red 5th gen, i think it looks really nice and even more so if you get a CF trunk as well
Old Aug 21, 2007 | 11:35 AM
SunnyTO's Avatar
Default Re: (viper_boy403)
Hmm.. i think i'm gonna paint the roof black.
I just hope it doesnt look too wack with just hte black hood and white body. I won't be getting a CF hood till about Nov.
EDIT: Most pix are of preludes with the pillar also painted, i'm only doing my roof, anyone have any pix of that? Thnx.
Modified by SunnyTO at 3:07 PM 8/21/2007
Old Aug 21, 2007 | 12:14 PM
prelude_h22vtec's Avatar
Default Re: White or Black roof? (M@)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M@ &raquo;</TD></TR><TR><TD CLASS="quote">That might keep you warmer in the winter time +1 for a usefull mod</TD></TR></TABLE>
or hotter in the summer time. if you dont have a/c, go completely white.
Old Aug 21, 2007 | 12:15 PM
oh wait, you're in canada, silly me. paint the roof black!
Old Aug 21, 2007 | 01:18 PM
Finest's Avatar
Default Re: (prelude_h22vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude_h22vtec &raquo;</TD></TR><TR><TD CLASS="quote">oh wait, you're in canada, silly me. paint the roof black!</TD></TR></TABLE>
LOL! That made me laugh.
I'm all for the Panda look. I say do the pillars as well.
Old Aug 21, 2007 | 01:32 PM
E-Money's Avatar
Default Re: (Finest)
Old Aug 21, 2007 | 02:15 PM
Eddiebx's Avatar
why not paint the rest of the car black to match,
Old Aug 21, 2007 | 02:25 PM
Apex1972's Avatar
I wanted to do the same thing to my 92 Si. I think it will look good. I also highly recommend the 5th gen. glass sunroof swap. Very easy to install and not much heavier than the crappy rust out metal roof.Let me know if ya want to do this swap, I can tell you how easy it is!!!
Old Aug 21, 2007 | 02:30 PM
SunnyTO's Avatar
Default Re: White or Black roof? (Apex1972)
Dude that was exactly what i wanted to do, but i can't find the 5th gen sunroof anywhere.
i went to the Honda dealership and they want an arm and a leg for it.
Anyways if you can tell me the steps to doing the swap it'd be great. I'm gonna check out a scrapyard see if i can salvage anything.
Old Aug 21, 2007 | 02:33 PM
whisperice's Avatar
I think that it looks good, reminds me of the mitsubishi eclipse/talons with the black tops. Its a totally different look. Id consider doing it.
Old Aug 21, 2007 | 02:34 PM
Apex1972's Avatar
all you need is the glass, the brackets that hold it to the sliders, and a few washers or shims. the reason I say you need the shims is because the glass sits higher than the metal roof does. You can do it another way that was posted somewhere else , but I did not want to use the existing brackets. You can do it either way you like though. I love mine!!!
Old Aug 21, 2007 | 02:44 PM
SunnyTO's Avatar
Default Re: (whisperice)
I wont be doing tyhe full 2 tone look, with the painted pillars, just the roof.
What am i doing exactly with all those pieces lol. If anyone has the link to the DIY prelude roof it'd be great, i tried ssearching but no luck.
Old Aug 21, 2007 | 04:05 PM
Apex1972's Avatar
Default Re: (SunnyTO)
it is simple, remove your interior panel first. then you will take the 8 10mm nuts out that are holding the metal panel to the brackets. then remove the brackets, they are held on with phillips head screws. you will then put the 97 up brackets in the place of the old ones. then bolt the glass to the new brackets. after you close the roof, you will see that the glass sits higher than the old one did. you will need to have the entire headliner out so you can see the 10mm bolts that are holding the assembly to the roof. depending on your particular car, you will add shims or washers to these bolts. on mine, the front 4 bolts needed about 3 washers each. again, your results may be different. all you are doing is lowering the whole assembly down to make the glass flush. the only link I have seen gives instructions on drilling your existing brackets. using the newer brackets just means you do not have to do any drilling.oh yeah, one more thing is you have to grind off 2 tabs that are on each side of the glass panel. very easy man!!! do it!!
Old Aug 21, 2007 | 07:16 PM
M2B4's Avatar
Default Re: (Apex1972)
not my car but heres what ur looking 4
Old Aug 22, 2007 | 10:45 AM
Apex1972's Avatar
Default Re: (M2B4)
that looks hot!!! does that car have a carbon trunk too????
Old Aug 22, 2007 | 06:42 PM
SunnyTO's Avatar
Default Re: (M2B4)
Holy crap that's hot.. I'm convinced now. Black roof FTW!
pharbehind
Oct 9, 2006 01:57 PM
hatch34
May 3, 2005 11:06 AM
92BlackSi
Mar 16, 2004 08:22 AM
