rubbing brakes.
just finished my brake set up, and when i went to do a test drive i am getting some rubbing noise on the rear brakes. almost sounds like my pads are gone, but i put on all new pads and rotors all around.
the car brakes fine, no vibration or shimmies, only that noise. i have noticed that the noise has decreased the more i drive, but then again this is my weekend warrior so i don't drive often.
any ideas HT?
any ideas HT?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95vxtealhatch »</TD></TR><TR><TD CLASS="quote">Does it rub when your off the gas? If it does then id say check your pads, and make sure you didn't forget soemthing. Like the shims</TD></TR></TABLE>
yeah it rubs when on/off the gas. i just IM blueintergaboy, and he suggested the e-brake cable. which will make sense if it's not disengaging and being that i replaced it with the conversion.
i will check it out then respond with an answer!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
i will check it out then respond with an answer!</TD></TR></TABLE>
answer: the stupid dust shield was slightly bent, rubbing on the rotor. problem solved.
allnaturalb16
Honda Civic (2001 - 2005)
Apr 30, 2007 11:26 AM
carsaregood
14
Oct 26, 2003 08:47 AM
