Engine Stalls out when braking or coming to a stop
Old Aug 21, 2007 | 06:54 AM
spyda man's Avatar
Default Engine Stalls out when braking or coming to a stop
a majority of the time when I come to a stop my engine stalls out, my check engine is on with 2 codes of P0170 Fuel Trim Malfunction (Bank 1) P0171 System too Lean (Bank 1), I'm not really too sure how to fix these two problems, but I think the most common problems are my O2 sensors, a possible misfire, and fuel filter, even so I don't know how that would stall out my engine when I come to a stop, (it usually acts up when speed is decreasing around 30 and below) any advice would be greatly appreciated.
Old Aug 21, 2007 | 07:00 AM
sicones's Avatar
Default Re: Engine Stalls out when braking or coming to a stop (spyda man)
when engine/car, sounds like you need a tune up
Old Aug 21, 2007 | 09:31 AM
b20beast978's Avatar
sounds like your fuel filter is clogged. My motor used to do the same thing but excpet when i was on hills it would stall out. swapped out the fuel filter and now its runs smooths on hills
Asmooh
Apr 17, 2014 06:23 PM
blk_eg4
Aug 3, 2006 08:27 PM
boost killz
Jul 30, 2001 11:04 AM
