aftermarket headers
* B A N N E D *
i have a one piece header by mistake i trash out the stock one so i want to know if i can install the aftermarket one and then open two holes in the part where the 4 pipes are united will it work????
Wait you have the top part of a an 2 piece aftermarket header and still have the OEM bottom part?
I can't figure how to read this post.
* B A N N E D *
i use to have the stock b16 header, ok i dont have it anymore i trash it out.
now i have a one piece header is a complete header it doenst come in two parts is just one piece . so since the stock header had both sensors on the part where the four pipes are united.
i wanna know if i can drill two holes on the aftermarket header where the four pipes are welded in, so i dont get a check engine light
let me know if you get it now jajaja im sorry i know is kind of confusing
stop trying to sound intelligant and say what need to be said
and i believe its ( i threw the old one out ) not "i trash it out"
and just get O2 sensor bungs and get the welded in simple; done!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garageEF »</TD></TR><TR><TD CLASS="quote">this thread makes my brain itch...
X2
</TD></TR></TABLE>X2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juanchoenuncrx »</TD></TR><TR><TD CLASS="quote">i use to have the stock b16 header, ok i dont have it anymore i trash it out.
let me know if you get it now jajaja im sorry i know is kind of confusing</TD></TR></TABLE> It only was hard because you type like a escaped mental patient.
Yes, you can have a bung welded in for another 02.
* B A N N E D *
ok basically i just need to get two 02 sensors on my aftermarket headers for my b16 . the header has only one hole downstream near the converter so i need to drill two holes upstream of the header can i do that????????????
okay, you need two holes, have one hole, 2-1=1. You need to drill one hole, have a bung welded on, put in ur o2 sensors, and go drive. I hate threads like this
* B A N N E D *
well somebody here told me that if i dont put the two sensors upstream i was going to get an engine light because if i put it donstream i wont get air and fuel ratio so let me know
EM2ABOO
Honda Civic (2001 - 2005)
Oct 25, 2009 10:07 AM
