puttering and blue smoke
Old Aug 20, 2007 | 09:09 PM
patrick4588's Avatar
Default puttering and blue smoke
well i got tuned and i was driving around beatin on the car a lil bit and it just started to putter and progressively got worse until it sounded like it was running on 3 cylinders. i limped it home and pulled the plugs. cylinders 1 and 2 were fine. 3 and 4 were covered in oil, along with the spark plug wire (leaking tube seals). it was a lot of oil on each plug to the point it was dripping off and onto the ground when i pulled it. the nuts holding the valve cover down on the left side by those two cylinders were kinda loose and i think thats how the oil got down in them. well i replaced the tube seals and cleaned up the tube a little with a rag. i started the car back up, but didnt drive anywhere. i let it idle for about 10-15 seconds and it was blowing a lot of blue smoke. obviously from the oil being in the combustion chamber. how long should it take for this to burn off? i dont know if its driving better since i just finished with it and im going to bed. im gonna drive it tomorrow morning around the block and see how it does.
Old Aug 20, 2007 | 09:25 PM
tony413's Avatar
blue smoke = oil
white smoke = gasket
honestly it deapends on how much oil is in the cylinder let it idle untill it stops also have you checked the gasket an did you do a leakdown test before the turbo was put on
Old Aug 20, 2007 | 09:30 PM
didnt do a leakdown test, but i did a compressino test months ago and it was fine. the number 3 spark plug wasnt tightened down enough and was kinda loose. and the nuts on the left side of the valve cover were not as tight as they should be. from what i can tell, oil leaked from the tube seals into the 3 and 4 chamber and fouled the plugs out. it seemed like a good bit of oil. i pulled the cover off and re did everything. hopefully it will be fine tomorrow.
Old Aug 20, 2007 | 09:42 PM
tony413's Avatar
Default Re: (patrick4588)
ok best of luck
Old Aug 21, 2007 | 12:19 AM
1Quikgsr's Avatar
your rings probably went, do a leakdown
Old Aug 21, 2007 | 04:55 AM
wouldnt it be kinda weird that my rings went in 3 AND 4 at the same time though? plug the oil on the spark plug wire and the tube leads me to be believe its just the tube seals. gotta hope for the best right?
Old Aug 21, 2007 | 09:24 AM
did a leakdown test and my rings are gone.
cylinder 1 - 15%
cylinder 2 - 11%
cylinder 3 - 89% !!!
cylinder 4 - 11%
Old Aug 21, 2007 | 01:18 PM
street dream gsr's Avatar
* B A N N E D *
blue smoke is just not good. now you can build it. be positive about it.
Old Aug 21, 2007 | 01:23 PM
yeah i can, but im a college student and this is my daily driver. so going without the car still sucks.
Old Aug 21, 2007 | 02:28 PM
thelate1's Avatar
what was this tuned with?
Old Aug 21, 2007 | 04:05 PM
quicksilver1689's Avatar
i ♥ snails
the infamous cylinder 3
Old Aug 21, 2007 | 05:20 PM
crome pro
Old Aug 22, 2007 | 09:06 PM
JaredKaragen's Avatar
hope the ringlands didn't go.
Old Aug 22, 2007 | 09:12 PM
91tegrals's Avatar
damn man that sucks hope you get that **** fixed.
Old Aug 23, 2007 | 09:47 AM
just gonna do a stock rebuild for now and start on building a block thats sleeved and can handle some high hp.
Sagara09
Oct 2, 2011 02:11 PM
Red-Rag-B18
May 4, 2010 07:04 PM
Nordy
Feb 24, 2007 07:40 PM
copmagnet
Nov 12, 2004 10:01 AM
jaymes2030
Jan 19, 2004 07:14 PM
