Found this while taking off my oil pan....any suggestions to fix it???
Old Aug 20, 2007 | 07:57 PM
methos713's Avatar
Default Found this while taking off my oil pan....any suggestions to fix it???
while rebuilding my d16z6, I found this problem after taking off my oil pan. Of all the shiet, this has to happen...its the lower screw hole for the a/c bracket. Anyone deal with something like this before? Is there any way to fix it? I tried to screw in the bolt, but it looks to be striped. Tap a bigger thread hole into it and teflon tape it?
Old Aug 20, 2007 | 08:00 PM
JDMisGOOD's Avatar
Default Re: Found this while taking off my oil pan....any suggestions to fix it??? (methos713)
You could have it welded, re-drilled, and tapped...
Or just clean it really really well and bust out the JB Weld and put a stud in it. Then just use a nut to fasten the a/c bracket.
^That's my inner hillbilly coming out^
I highly recommend the first option. But the 2nd should work...
Old Aug 20, 2007 | 08:12 PM
methos713's Avatar
Default Re: Found this while taking off my oil pan....any suggestions to fix it??? (JDMisGOOD)
welded with what material? And as for the drill...drill it with a smaller size drillbit then tap with the right bolt size tap? Thanks.
Old Aug 20, 2007 | 08:43 PM
BILLETGRIP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by methos713 &raquo;</TD></TR><TR><TD CLASS="quote">welded with what material?</TD></TR></TABLE>
aluminum
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by methos713 &raquo;</TD></TR><TR><TD CLASS="quote">And as for the drill...drill it with a smaller size drillbit then tap with the right bolt size tap?</TD></TR></TABLE>
find out what size bolt goes in it then google a tap drill chart.
Old Aug 20, 2007 | 08:49 PM
methos713's Avatar
Default Re: Found this while taking off my oil pan....any suggestions to fix it??? (BILLETGRIP)
a simple leaky oil pan gasket change...and it leads to this...more problems...now I got to take out the crank, rods, and pistons. Anyhow...Thanks.
Old Aug 20, 2007 | 08:52 PM
BILLETGRIP's Avatar
if you went the jb weld way you wouldnt have to do all that
Old Aug 20, 2007 | 09:14 PM
methos713's Avatar
how well does jb weld hold? Sorry, never tried it.
Old Aug 20, 2007 | 09:36 PM
Legion's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by methos713 &raquo;</TD></TR><TR><TD CLASS="quote">a simple leaky oil pan gasket change...and it leads to this...more problems...now I got to take out the crank, rods, and pistons. Anyhow...Thanks.</TD></TR></TABLE>
Psh, hell no. Would you really be willing to do that?
Anyway, those AC bolts are long, and I seriously doubt that missing 1/4" of thread is going to matter at all. If it were me, I would do this:
1. JB Weld the hole shut to prevent oil leaks.
2. Cut the bolt down so that when it's fully threaded in it won't contact the blob of JB Weld at the end.
3. If the bolt feels stripped, just tap it out one size larger and use a 1mm larger bolt.
Old Aug 20, 2007 | 09:49 PM
methos713's Avatar
Default Re: Found this while taking off my oil pan....any suggestions to fix it??? (Legion)
I would really like to aluminum weld that hole though. How well does jb weld hold?
Also, someone from the tech area suggested just welding it shut...use a bigger drill and tap...and bigger bolt or hex plug.
Old Aug 20, 2007 | 09:56 PM
Legion's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by methos713 &raquo;</TD></TR><TR><TD CLASS="quote">Also, someone from the tech area suggested just welding it shut...use a bigger drill and tap...and bigger bolt or hex plug.</TD></TR></TABLE>
That's what I said too!
And the degree to which JB Weld "holds" is wildly variant, depending on how well you prep the surface. It's nothing compared to a real weld. Your best bet is to cut the bolt down a bit so it won't contact the JB and dislodge it.
Old Aug 20, 2007 | 10:02 PM
BILLETGRIP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Legion &raquo;</TD></TR><TR><TD CLASS="quote">
3. If the bolt feels stripped, just tap it out one size larger and use a 1mm larger bolt.</TD></TR></TABLE>
Old Aug 20, 2007 | 10:41 PM
methos713's Avatar
Searching for more info on jb weld and tomorrow, I'm off to buy some...if that doesn't work out...I'll try calling some shops here to see if they will aluminum weld it for me.
Old Aug 21, 2007 | 03:53 AM
flyrod's Avatar
Just clean the oil out of the threads and put honda bond (grey silicone) on the A/C bolt when you install it.
Old Aug 21, 2007 | 07:27 AM
Hybrid96EK's Avatar
Disassembling that engine to fix that is way more work then a Z6 is worth. Honestly. Clean it up and try the JB weld. Then don't use the wrong bolt in the hole (too long) and you won't have this problem again.
Old Aug 21, 2007 | 08:26 AM
methos713's Avatar
Default Re: Found this while taking off my oil pan....any suggestions to fix it??? (Hybrid96EK)
yeah, it looks like the longer bolt was in there...plus the block is on a engine stand.
Old Aug 21, 2007 | 08:55 AM
jeffsciv23's Avatar
i would take the AC off and just JB the bolt in the hole and cut the rest of it off, kinda use it as a plug. but thats if you don't care about AC.
Old Aug 21, 2007 | 07:27 PM
methos713's Avatar
Default Re: (jeffsciv23)
taking it to the machine shop to have it aluminum weld tomorrow...after that a rebuild.
Old Aug 21, 2007 | 07:36 PM
Legion's Avatar
* B A N N E D *
Default Re: (methos713)
Lol, WTF! Sounds like you needed an excuse to rebuild
Old Aug 21, 2007 | 08:50 PM
methos713's Avatar
Default Re: (Legion)
lol, yeah...it does need too...at 200k miles...funds coming out of my turbo project.
methos713
Aug 21, 2007 07:25 PM
ericschimmel
50
May 14, 2007 07:22 PM
Nishant
Jul 17, 2006 06:23 AM
the.hamburglar
24
Jul 19, 2005 08:39 PM
Shakes
Sep 18, 2004 11:41 AM
