Distributor cap difference ?
Old Aug 20, 2007 | 06:25 PM
crazyguy's Avatar
Default Distributor cap difference ?
i have a jdm b16a SiR II engine swap.i was trying to buy the dizzy cap and rotor to replace the old ones.i got the integra gsr dizzy cap and rotor from advance auto parts and they dont match with my jdm one.whats the right dizzy i should get?thanks.and also how to take the rotor off??
thanks
Old Aug 20, 2007 | 06:29 PM
b16a3delsol's Avatar
Default Re: Distributor cap difference ? (crazyguy)
94-97 dohc del sol is the cap you need.
Old Aug 20, 2007 | 06:31 PM
crazyguy's Avatar
Default Re: Distributor cap difference ? (b16a3delsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a3delsol &raquo;</TD></TR><TR><TD CLASS="quote">94-97 dohc del sol is the cap you need.</TD></TR></TABLE>
how about rotor and i cant find the retaining screw.do u knwo how to remove the rotor?thanks
Old Aug 20, 2007 | 06:36 PM
gsrhatch2356's Avatar
it is kind of a pain but if you look on the bottom side of the rotor and push back the plastic housing a little you will see the retaining screw
Old Aug 20, 2007 | 06:46 PM
pauley_lsvtec's Avatar
usually you have to trurn the engine over in order to get the screw to face upwards.
Old Aug 20, 2007 | 06:48 PM
forcefedferio's Avatar
Default Re: Distributor cap difference ? (pauley_lsvtec)
yeah you also won't be able to see it if you don't pull that plastic shroud off.
spaceman
Aug 30, 2016 02:43 PM
tunedek
Apr 14, 2007 03:03 PM
A.E Motoring
Jul 17, 2006 04:16 PM
D
Oct 6, 2001 12:52 PM
KayOs
Sep 8, 2001 08:54 AM
