1997 Prelude, AC stopped working
1997 Prelude, AC stopped working yesterday
The light on the control switch comes on
The ac system is properly charged
Tried bypassing the pressure switch already
Both fan and ac clutch are tested working
Double checked all fuses
There is no power to the fan or clutch with the car running and the ac turned on... what could this be?
What relay does the ac system run off of?
The system was working fine but i noticed the car starting to get hot, did some diagnosis and found the cooling system fan to be dead. One of the things i did was to jump the relay for the cooling fan... seems like it stopped working afterwords but not 100% sure on that cause i didnt try using the AC again till the next day.
Any input would be fantastic
okay well i think i found the problem, the a/c thermostat switch is fried! I removed it and popped it open to find burn circuitry
i'll no for sure when i replace it but looks good!
Single-Cam
16
Feb 10, 2016 07:23 PM
