Timing belt postion on camshaft: does this looks ok?!
Old Aug 20, 2007 | 05:57 PM
Nathan007's Avatar
Default Timing belt postion on camshaft: does this looks ok?!
I tried centering it on the camshaft pulley but everytime i try rotating the crankshaft a few turns to set everything right, it comes back to this position.. It was pretty much like that when i removed it at first..
Is there a reason i cannot keep it centered, or it's just "like that'
thanks
Old Aug 20, 2007 | 06:03 PM
Aahj's Avatar
Default Re: Timing belt postion on camshaft: does this looks ok?! (Nathan007)
it's just like that...you're fine...
AJ
Old Aug 20, 2007 | 09:24 PM
tsiah's Avatar
thats how it rolls!
its normal
Old Aug 20, 2007 | 09:57 PM
Eddiebx's Avatar
its suppose to be on the outter edge, only be concerned if u see it start to ride past it, then u have problems.
Old Aug 21, 2007 | 03:58 AM
TouringAccord's Avatar
H-T Order of Merit
like stated above, it's fine.
The reason it keeps coming back is because it keeps resetting itself after you move it. Only be concerned if it goes over the edge.
Old Aug 21, 2007 | 04:32 AM
Nathan007's Avatar
alright
i'll keep an eye on it , anyways i'll have to tear it down again in a moth or so
Jamm_95
Mar 26, 2015 08:03 PM
aaaabbbb
Oct 5, 2004 03:02 PM
blufke
Mar 7, 2003 11:39 AM
rokestah
Feb 3, 2003 04:20 PM
jwwskatr
Nov 14, 2002 08:01 PM
