Water in the sparkholes
Old Jun 13, 2002 | 09:56 AM
FitCRX's Avatar
Default Water in the sparkholes
I got water(filled) in my spark plug holes....what damage did it do if any at all?
Old Jun 13, 2002 | 12:11 PM
Perfectionist's Avatar
Default Re: Water in the sparkholes (FitCRX)
None, if the spark plugs were still in the holes. Blow out the water and let it dry out. Otherwise you may get some mis-fires.
Old Jun 13, 2002 | 02:46 PM
fsarfino's Avatar
Default Re: Water in the sparkholes (Perfectionist)
also if you were not cleaning your engine when the water got in I would suggest some new sparkplug wires.
Old Jun 13, 2002 | 03:20 PM
martini's Avatar
Default Re: Water in the sparkholes (fsarfino)
when my B16A came over on the boat from japan, it had water in the spark plug holes.
It was sitting there long enough to do damage. One of the spark plugs wouldn't come out, and it eventually just broke off the threaded part from the rest of the plug.
Observe:
Old Jun 13, 2002 | 03:55 PM
kyler's Avatar
Default Re: Water in the sparkholes (martini)
Ouch... what did you have to do to save the head? Or was it screwed?
Old Jun 13, 2002 | 07:31 PM
dpo95si's Avatar
Default Re: Water in the sparkholes (kyler)
should have soaked it in wd-40 or some other penitrating oil. bought a zc out of a junk yard that sat out in the open for a year and a half. soaked them and they came right out
Old Jun 13, 2002 | 08:56 PM
FitCRX's Avatar
Default Re: Water in the sparkholes (dpo95si)
Thanks guys...I let it sit open in the sun today dryed them out...seems to be running better...getting a code 17 now...VSS?
Old Jun 13, 2002 | 09:56 PM
Arturbo's Avatar
Better than steak
25 Year Member
Or get a pump to get the water out. I had the same problem one time and i just let it sit there untill it was dry. In texas heat it only took a day.
art
Old Jun 13, 2002 | 10:22 PM
tonyxcom's Avatar
Default Re: Water in the sparkholes (Arturbo)
I had that happen after I washed my sr20. I used some napkins and a stick to push it down and soak it up. It missfired like a SOB under load.
I also broke a spark plug out of a head before too. I soaked it in everything for a whole day. It still broke.
We took the head to a machine shop and they got the threaded part out with an Ez-Out for only 10 bux. They chased the threads for us too.
blanco617
Apr 2, 2007 10:41 AM
Zaakro
Feb 1, 2007 11:29 AM
JoHA
Apr 6, 2006 01:53 PM
TheNasty0ne
35
Apr 8, 2005 08:27 AM
hatchback_al
15
Jul 21, 2004 02:15 AM
