H22A vs B18
Old Aug 20, 2007 | 04:17 PM
slacks's Avatar
Default H22A vs B18
I'm in the market for an older honda to tune up but I'm stuck deciding between an accord (h22) or a civic (b18) (either or will be swapped later on). Regardless of the choice the engine will be turbo'd so I'm wondering which car I would have the potential to get more HP and torque out of?
I'm sorry If this has been covered before but i need to know :/
Old Aug 20, 2007 | 05:09 PM
shad0wslay3r's Avatar
I
Old Aug 20, 2007 | 05:10 PM
slacks's Avatar
Default Re: (shad0wslay3r)
you :/
Old Aug 21, 2007 | 07:29 AM
RaceCarRyne's Avatar
Default Re: (slacks)
when did a civic come with a b18?
Old Aug 21, 2007 | 09:39 AM
slacks's Avatar
Default Re: (RaceCarRyne)
i'm just saying b18 for a potential swap
Old Aug 21, 2007 | 10:05 AM
h22crxpwr's Avatar
Default Re: H22A vs B18 (slacks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slacks &raquo;</TD></TR><TR><TD CLASS="quote">I'm in the market for an older honda to tune up but I'm stuck deciding between an accord (h22) or a civic (b18) (either or will be swapped later on). Regardless of the choice the engine will be turbo'd so I'm wondering which car I would have the potential to get more HP and torque out of?
I'm sorry If this has been covered before but i need to know :/ </TD></TR></TABLE>
you have that all mixed up. forget the accord and go with the civic with H22. Accord is worthless to put an h22 in. heavy sled.... 92-95 civic with H22 =
Old Aug 21, 2007 | 10:07 AM
Golden Eagle's Avatar
Default Re: H22A vs B18 (h22crxpwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22crxpwr &raquo;</TD></TR><TR><TD CLASS="quote">
you have that all mixed up. forget the accord and go with the civic with H22. Accord is worthless to put an h22 in. heavy sled.... 92-95 civic with H22 = </TD></TR></TABLE>x2
Old Aug 21, 2007 | 11:29 AM
98vtec's Avatar
moderator emeritus
scott bryars did really well in an NA accord.
and if you are boosting, why is this in the ALL MOTOR forum?
Old Aug 21, 2007 | 12:27 PM
slacks's Avatar
Default Re: H22A vs B18 (98vtec)
would the 500lb difference be worth the instability of a civic though? my friend's civic shakes around 80mph and it's a 95 i believe.
plus I'm not sure I could afford an h22 into a civic too messy to do on my own
Old Aug 21, 2007 | 12:44 PM
Jay_Sensing's Avatar
If he has instability issues, there is more to it. The car is fine as I have no problems at the big end of the track on slicks with instability and I am running a lot faster than 80.
And yes, the 500 lbs is worth it.
Old Aug 21, 2007 | 03:29 PM
h224thgensedan's Avatar
o yea 500lbs is worth. Weight to power.
Old Aug 21, 2007 | 07:10 PM
ekBlackHatch's Avatar
not even a question get the civic do a h22 with a H2B kit and get a itr tranny with lsd or a si tranny then get the mfactory 4.9 FD and then smile and call it a day
Old Aug 22, 2007 | 07:49 AM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slacks &raquo;</TD></TR><TR><TD CLASS="quote">would the 500lb difference be worth the instability of a civic though? my friend's civic shakes around 80mph and it's a 95 i believe.
plus I'm not sure I could afford an h22 into a civic too messy to do on my own</TD></TR></TABLE>
your friend has issues with his civic then.... it isnt supposed to shake. and despite what you might hear the H is not that much heavier than the B series. I have it in a crx and it drives fine... no shaking or any kind of problems driving.. trust me you will be very happy with the H22 in a civic. its actually not a very difficult swap, let me know and i can get you the parts for it at a really good price.. mounts, axles. i can even make you a harness for it so all you have to do is plug it in..not trying to be a salesman but i can save you money and make your swap easier to do it yourself, if you are interested.
Old Aug 22, 2007 | 09:50 AM
alterdcreations's Avatar
h22 civic
h23 civic
97mm stroke h22 civic
Old Aug 22, 2007 | 10:26 AM
Default Re: H22A vs B18 (alterdcreations)
95mm stroke h22 DA
NWbumblebee
Nov 29, 2010 04:46 PM
Diplomat1929
May 25, 2006 06:19 AM
snatch13
Dec 1, 2003 06:51 AM
KenRed
Oct 20, 2003 10:43 AM
EKB18BPR3
Sep 5, 2002 11:21 AM
