NEW SETUP FOR NEXT YEARS HOT ROD CLASS
Old Aug 20, 2007 | 03:56 PM
jasonp's Avatar
Default NEW SETUP FOR NEXT YEARS HOT ROD CLASS
HERES THE NEW SETUP FOR NEXT YEARS HOT ROD CLASS...JUST WANNA GET SOME FEEDBACK, WILL HOPEFULLY BE UP AND RUNNING WITHIN THIS MONTH AND IF ANY SUGGESTIONS IT WOULD BE APPRECIATED.
THANKS,
JASON
BIG PROPS TO TONY1 FOR ALL THE HELP!
Modified by jasonp at 5:16 PM 9/9/2007
Modified by jasonp at 5:19 PM 9/9/2007
Old Aug 20, 2007 | 04:02 PM
coupe01844's Avatar
looking good so far..
Old Aug 20, 2007 | 04:32 PM
I B BANGGIN's Avatar
Default Re: (coupe01844)
nice to finally see what you been doing jason...cant wait to line them up
Old Aug 20, 2007 | 04:36 PM
bambooluv's Avatar
Jason you sob, how you been bud....that Tomball air kick some sense into you to go turbo? Nice to see you are still into sport-compact drag Bud. Your old pal.
Pdang
Old Aug 20, 2007 | 04:45 PM
jasonp's Avatar
thanks guys .. pdang good to hear from you.. and I plan on running this thing real soon..
ninesecrx's Avatar
Default Re: (bambooluv)
Sweet
Old Aug 20, 2007 | 04:56 PM
SPOOLINmatt's Avatar
Default Re: (ninesecrx)
thats looking goood, whats up with the rad in the driver compartment?
and whats those brackets off the valve cover for¿
Old Aug 20, 2007 | 05:06 PM
DaveF's Avatar
Default Re: (SPOOLINmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt &raquo;</TD></TR><TR><TD CLASS="quote">thats looking goood
whats those brackets off the valve cover for¿</TD></TR></TABLE>
look like individual coil brakets to me ?
looks awsome Jason !! did you pick that stuff up off of Adam's car ?
also which chassis is that ? EG ?
Old Aug 20, 2007 | 05:13 PM
jasonp's Avatar
Default Re: (DaveF)
yes I got that stuff from adamf and it's bracket's for individual coils and the radiator is in the pass. side and I plan on running it there.. also the car is a 95 coupe..
Old Aug 20, 2007 | 05:45 PM
DaveF's Avatar
Default Re: (jasonp)
bad *** ! got some nice parts on there
are you using motec as well ?
Old Aug 20, 2007 | 05:53 PM
jasonp's Avatar
Default Re: (DaveF)
no the motec isn't going to work that adam had so I using the s300 for now.. don't know how much power it will take (s300) but tony1 and me are going to give it hell...
Old Aug 20, 2007 | 06:10 PM
FMUNK's Avatar
Default Re: (DaveF)
Lookin Good,
Radiator is propably a bad idea, it gets so hot in these cars sitting in the lanes to begin with. I think it is going to be miserable towing it back to the pits, etc...
BUT mainly, if you were to lift a head and that thing let go...............you are going to find out real fast what McDonalds Coffee feels like when they do not put the lid on so good.
The front traction bar mount is weak and Very unsafe. Trust me there is a HUGE amount of force being put on that front mount, which transfers to the chassis.
If you want to talk about it feel free to hit me up on PM.
Old Aug 20, 2007 | 06:16 PM
RPRacing's Avatar
Default Re: NEW SETUP FOR NEXT YEARS HOT ROD CLASS (jasonp)
looks excellent Jason.
Old Aug 20, 2007 | 06:59 PM
CHEETAH's Avatar
nice.
why put the radiator in the car ? i say you move the battery elsewhere then play with that room to mount the radiator even if it means mini fluidyne or fit it sideways near the coil .... like kenny tran ?
Old Aug 20, 2007 | 09:21 PM
94 si hatch's Avatar
Looks good Jason,cant wait to see it run.
Old Aug 20, 2007 | 09:33 PM
f@sth@tch89's Avatar
Default Re: (94 si hatch)
looks good. what kind of hp you think its going to make? good luck with it.
so many steel braided lines going everywhere....
Old Aug 20, 2007 | 09:52 PM
RCautoworks's Avatar
Sick setup
Old Aug 20, 2007 | 09:55 PM
808 NA1's Avatar
Awesome looking setup! Just curious about the coupling off the turbo. Why is it silicone coupled off the V band? Is that just temporary?
Old Aug 21, 2007 | 05:17 AM
Autoworks's Avatar
Default Re: NEW SETUP FOR NEXT YEARS HOT ROD CLASS (808 NA1)
Very nice, that's one funky manifold
Old Aug 21, 2007 | 07:24 AM
Bisimoto's Avatar
Default Re: NEW SETUP FOR NEXT YEARS HOT ROD CLASS (Autoworks)
Nice set up, Jason. Lovely wheels too. Kindly relocate the dry sump tank breather away from the front of the slick/tyre...you do not want to know what happens if it "overflows" for some weird reason during a pass...and it can happen.
Goodluck!
Old Aug 21, 2007 | 07:34 AM
jasonp's Avatar
Default Re: NEW SETUP FOR NEXT YEARS HOT ROD CLASS (Bisimoto)
great advise Bisi.. didn't think about that..
Old Aug 21, 2007 | 04:24 PM
fast is fun's Avatar
I would check with NHRA about the rad. I don't think that it is legal.. also might want to protect the oil sump from the tire with a bar. what about an alt.? thats an small batt. with out one ( maybe go with a 16volt) JMO
I would grab a rule book to check a few things and NHRA chassis book
Thank
Old Aug 21, 2007 | 04:39 PM
jasonp's Avatar
Default Re: NEW SETUP FOR NEXT YEARS HOT ROD CLASS (fast is fun)
changing up the radiator asap and I will fix the dry sump and Im running the alt. also.. I will change the battery later...
Old Aug 21, 2007 | 04:41 PM
good man
Old Aug 21, 2007 | 05:00 PM
accordking's Avatar
damn, I might just build another HotRod car.
