help with ecu rechipping!!
Old Jun 13, 2002 | 09:46 AM
p-boy's Avatar
Default help with ecu rechipping!!
hmm.. if i chip a d15 ecu(p08) with a b16a(p30) ecu chip like a spoon program or something i have like a bunch of em lying around here.. just wana ask cause the plugs are smilar to a b16a (p30) ecu but im not sure if it will run the engine.. help me!!!! in short i f i rechiop the p08 ecu with a dohc (p30) chip ..will the p08 ecu become a dohc ecu?
Old Jun 13, 2002 | 10:46 AM
Katman's Avatar
Default Re: help with ecu rechipping!! (p-boy)
well you need to use a DOHC VTEC program that doesn't look for a knock sensor(KS) on the P08 ecu, since the P08 doesn't have a KS. If you have a stock P30 program and you some want to put it on the P08 ecu, the P08 ecu will throw a check engine light for the KS. and yes, if you put a DOHC VTEC program on the P08 ecu, it will become a DOHC VTEC ecu.
[Modified by Katman, 11:46 AM 6/13/2002]
Old Jun 13, 2002 | 11:59 AM
d15nonvtec's Avatar
Default Re: help with ecu rechipping!! (Katman)
the d15 motor has a p06 ecu check it first and i would advise against chipping it, it dont do nothin, i mean its somethin but not worth the trouble i think
Old Jun 13, 2002 | 04:08 PM
Katman's Avatar
Default Re: help with ecu rechipping!! (d15nonvtec)
...that's true if this guy IS actually running a DX/D15 engine. I'm assuming he asked if a DOHC VTEC/P30 program would work on a P08 ecu for just that reason....to power a DOHC VTEC engine.
Old Jun 13, 2002 | 07:04 PM
p-boy's Avatar
hi katman! well actually im running an eg b16a on my ferio.. my friend gave me like a bunch of around 4 p08 ecu so i was wondering if i can have someone to rechip it to obd1 ecu spec.. so i can sell it ..cash.. heheheh
Old Jun 14, 2002 | 11:08 AM
Katman's Avatar
I IM'd you...
Old Jun 15, 2002 | 12:21 PM
p-boy's Avatar
hi! rechipped a po8 ecu to a dohc spoon program ... runs ok but wats with thte check engine thingy? the cel always stays on... all the time..
Old Jun 16, 2002 | 03:26 PM
Katman's Avatar
like i said, it's probably because of the Knock Sensor. the P08 ecu does not utilize a kock sensor board
Old Jun 16, 2002 | 07:57 PM
p-boy's Avatar
tanx katman! hmmm do you have a skunk2 program for a p30? all i need is just the chip. plus shipping to the philippines1401 zip tnx
93slmdcvcsi
Feb 15, 2006 02:44 PM
matto2413
Nov 8, 2004 10:06 PM
Doubledeala
Oct 15, 2004 05:00 AM
