rsx injectors in em2
Have you needed bigger injectors with the stock injectors? If so, then I would say RSX injectors would be fine. I highly doubt you would get much more flow with the stock rail and fuel pump. You'd probably want to upgrade those as well, if you wanted bigger than the RSX fuel injectors.
yes, i already upgraded the fuel pump to a walbro 255lph fuel pump and a custom fuel rail with rsx-s injectors...
i've been boosting fine, but 3 months ago i blew my motor...
so im replacing pistons and rods...
and i wanted to know if the rsx-s injectors will hold more hp now that im upgrading more components
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJaeMac »</TD></TR><TR><TD CLASS="quote">yes, i already upgraded the fuel pump to a walbro 255lph fuel pump and a custom fuel rail with rsx-s injectors...
and i wanted to know if the rsx-s injectors will hold more hp now that im upgrading more components</TD></TR></TABLE>
If you want to hit the 300whp mark, get some RC540's.
Used2beAb16
Apr 10, 2005 05:42 PM
